dropping the back end?
harrison
Dont hate me for this ! i know everyone on here likes rake Ive never been a fan of it i just was wondering if its still possible to get my back end lower with my truck being lifted help??
mojoe
Southern Maryland
What lift are you running currently, and what is the total lift height?
If you have spacers front and rear, you could remove the rear spacers.
If you have a factory height truck with no lift, you could get rear drop springs.
You could add an aftermarket bumper and winch to the rear.
You could also cut a little off the rear springs until you have the desired height (would only do this as last resort)
I'm sure there are more options when I know a bit more about your truck. :)
Sent from my belly button...
harrison
harrison
i dont plan on cutting them lol but i have a 6 rcx and 1.25 body lift
mojoe
Southern Maryland
Thanks for the info. You could swap for their 4" rear spring, depending on how much rake you have. If that is too low, consider a small spacer in conjunction with the 4" spring. Or add weight to the rear with a bumper, etc. I don't think raising the front would be an option due to increased component angles. But I wouldn't rule that out without seeing it.
omaha123
Nebraska
5.9l CTD
why drop the back. max bilsteins up front would give you some cali.....
fastNugly
Toronto, ON
2012 Dodge Ram Sport CC
Was just about to say this ^^^^
Harrison, I know you're in Canada so if you need anything, we can ship to you without paying any duties.
The price you get is to your door and nothing more
But Bilsteins set to 1.4 with level you out.
