So if a goop catcher is so good, why aren’t they OEM installed?
The side with the longer hose. Its suppose to catch the crap before the vapor get pushed back into the engine block. If you reverse it like most people I see on videos, the steel wool can be sucked into the engine block when the vapor is pulled. So basically steel wool in the IN and the non steel wool is the OUT.Guys what side of the catch can does the filter with the steel wool go on? I took mine apart and now question what side to put it on? ugh! Sorry I'm a newbie ok. The side with the shorter hose or longer hose? I assume there is a flow direction here.
Where did you get your Hemi cover from? I like it!Some time ago Moe's Performance had some catch cans from BT with a flag engraved on it. I like the way it looked so I sold my original one and got one. I know they are more expensive, but it's done a good job for me and I like to support our preferred vendors.
Thanks brother!3G Customz
Jay
