Corsair2002
3.0L Ecodiesel
Hi all,
Was wondering if anyone knew the trick to disconnecting the EGT sensor connector. I need to disconnect the harness for an aftermarket install and cannot see if I am missing a some kind of locking pin, etc.
C
Corsair2002
3.0L Ecodiesel
Follow-up: If you need to find the EGT sensor connector, it is almost on top of the transmission on the passengers side, black connectors with a yellow locking tab. I believe the brown connector is likely for an O2 sensor.
timpaine1
New york
3.0 l v6 diesel
The connector(plug) that the headlight snaps into is burning out. I have to keep fixing it to get the light to work. I bought a new harness and installed it thinking the materials in the old one were defective but the new one is starting to burn out also. Wondering of anyone has experienced this or if anyone knows if this is a design issue?
