Max Steele
Hemi tick is worsening, and developing rough idle and lack of power? I'm fairly knowledgeable, but I guess didn't realize leaky exhaust could affect idle. Also had some "defective" tires that were causing a slight shimmy you could feel in the seat and occasionally steering wheel. Starts at highway speeds 55+. Dealer replaced all 4 with different brand, but I still feel it ever so slightly. Could other suspension parts be at play? Also, best diy way to clean injectors? Are there any aftermarket options for replacement headers that will cure the infamous from coming back? Lastly, what is the "tin-like" noise I hear when the trans is in a higher gear at lower speeds? Any cure for that? Sounds like a 4banger or 6 with euro exhaust.
