Factory 4X4 OffRoad too HIGH
ptrgrg
Aubrey, TX
2022 RAM 2500HD 4X4 Off Road package. This truck sits Too High
Can the LIFT spacers be Removed ?
Thx...
olyelr
Kewadin MI
Thx...
No. There are no spacers to remove. If you wanted it to sit lower you would have to swap out the front and rear coil springs for shorter ones.
Scottly
Safety Harbor, FL
HO 6.7 Cummins
Thx...
Is it a dealer-installed lift package? If so, you need to figure out what they did and reverse it. If not, OLYELR has it right.
P
ptrgrg
Aubrey, TX
Yes, it is Dealer installed off-road package
P
ptrgrg
Aubrey, TX
Thx OLYELR, I did not see any spacers when looking at it.
Will the 1500 4X4 Springs FIT ?
I wouldn't mind a softer ride, and do not plan to use truck off-road...
olyelr
Kewadin MI
No
DILLIGAF
Canadian Forces
Canada
Imagine thinking a factory truck is to high.... lol...
OC455
Central NY
Thx...
The Off Road package is what it is....
It's maybe an inch higher from discussions here from what I remember. Some say it doesn't raise the ride height.
Docwagon1776
Midwest
OP said it's a dealer installed package, so it's not factory if he's correct.
That said, have a family member who's got reduced mobility and you won't have to imagine. My dad lost both legs while I owned my 1500. The height became an issue pretty quickly, as trying to get him up and in the truck from his chair without hurting him was very problematic.
Docwagon1776
Midwest
Should be as simple as replacing with OEM parts, then, assuming they didn't swap the wheels/tires out for something that needs the extra lift. If they did, obviously you'll need to swap those out as well.
Dean2
Near Edmonton
If your truck says Off Road on the side it is not a dealer installed option, it came that way from the factory. My 2021 I ordered with the off road package as it comes with Bilstein Shocks, and they ride much better than the standard factory ones. Ride height is 1" difference. If the height is an issue have them install Mopar Power Running boards. Makes getting in and out a breeze and about the same price as changing it to get it 1" lower.
