Fan issue ?
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
2015 RAM V6 Penstar , Drove home tonight and heard a bubbling sound in the cab,popped the hood and you could hear it at the radiator, overflow tank was filled almost to the top
(When cooled back to normal level )
Started truck back up temp hit around 220 and NO fan and Active Air shutters were still closed !
I my ride to Mass. yesterday it did stay in the 210/225 range but never heard the bubbling sound !
To dark now to check the fuse, any ideas on anything else to check ?
Thanks
Jwithing
STL
I'm guessing bad thermostat if it was bubbling over. Kind of strange the fan wouldn't come on . Maybe a sensor?
Rado
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Thanks for your reply! It did not bubble over but you could hear it in a few seconds after shutting the truck off ! The overflow tank was expanded close to the top. Went down after cooled off ! Does the sensor control the fan and shutters ? The shutter was closed and did not open ! I will take it to the dealer (I do have extended warranty but looking for opinions to see if I get BSed by the dealer lol.. So far they have been good
Rado
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Dropped my truck off at the dealer today :O And go figure the ride over was normal and the Active air Shutter was opened when I checked :O So when they said everything worked I knew i was not being BS lol There is a update for the temperature module or whatever you call it lol And since the temp did go up to 230* they recommended replacing the thermostat ,and guess what they have to order the stat :O, Glad I have a warranty, So pick it back up tomorrow and will see if all goes well
RamCares
n/a
n/a
Hi Rado,
If you find you need any additional assistance while working with your dealer on this please let us know. Just send us a PM with additional details.
Julie
Ram Social Care Specialist
Rado
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Hi Rado,
Julie
Julie Thank you for your reply! I will PM you if I have any issues but do not expect to woth my dealer !
I know they did a update and changing the thermostat! Bummer is they had to order the thermostat :O But stuff happens :)
I am lucky as so far I ahve been very happy with my dealer :) ,,
