FBO Ram
EnanoHemi
Umatilla
So I have a 2015 Ram 1500 single cab with the 5.7 and 6 speed. I want to do long tubes, y pipe, to angle in dual out flowmaster exhaust, and CAI. How much faster would it make it?
RLJ10X
Southern Indiana
Let's back up a minute, kid.
What rear end gears do you have? Also, what size tires?
Power is all well and good. But if you don't have the "leverage" to utilize it, you're passing in the wind.
Pull Ya
U.S. MARINE VETERAN
Cedar Creek, Tx
Usual gain from a good set of long tubes(ARH) is about 25-30 rwhp with a custom tune.
Jay
RedSRT4Me
Scottsdale, Az
2015 CC Sport
A naturally aspirated FBO Ram imo
LT's
CAI
Tuner of choice highly recommend custom over included tunes.
Gears 4.10's
Muffler of choice
Single cabs with a driver are in mid to low 13's with some guys running mid 12's.
However if this is your first time drag racing at a track you'll probably go 14's the first couple passes till you make adjustments.
EnanoHemi
EnanoHemi
Umatilla
It has 22 inch wheels as of now.
EnanoHemi
EnanoHemi
Umatilla
LT's
CAI
Gears 4.10's
Muffler of choice
Would I have to build my transmission if I wanted to daily drive it?
RedSRT4Me
Scottsdale, Az
2015 CC Sport
I would say just use common sense.
I don't have a lot of experience pushing the 6 speed but the 8 speed handles 500 tq which a full built NA 5.7 hemi max effort could achieve.
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
Tire size not wheel.......you can put different diameter tires on a 22" wheel
Diameter of tire determines final gear ratio.
RLJ10X
Southern Indiana
3.92 rear end would be ok. If you have 3.55, or heaven forbid, a 3.21, you need 4.10s.
Make sure you're geared properly, and go from there.
The 5/645RFE is a decent tranny as long as you don't do full power downshifts. In other words, get off the gas, use your slap stick to get in the gear you want, probably second, then romp on it.
EnanoHemi
EnanoHemi
Umatilla
Well I was just trying to do some research before I start anything. It already has the flow masters on there. I’m not sure the gear ratio, and I can check the tire specs. But do you guys think it would be fine to daily drive with long tubes, exhaust, cai, and a tune?
RLJ10X
Southern Indiana
LTs, loud muffler, CAI is going to make a lot of noise, and something cool to brag about to your buddies, but if you're not geared to 3.92, or better still 4.10, you aren't making nearly as much forward progress.
In trucks with the 5/645RFE transmission, which you have, rear end gears are the foundation you build on.
Pull Ya
U.S. MARINE VETERAN
Cedar Creek, Tx
Yes, you can daily drive it. Alot of us with similar setups do it every day.
Jay
RLJ10X
Southern Indiana
WooHoo Enano! Lucky you.
Go for the other stuff!
Post another pic of your truck. I love RCSB (regular cab short bed) trucks.
EnanoHemi
EnanoHemi
Umatilla
8B62CB1D-02AB-4417-93A6-347516CD7D8F.jpeg BC91770B-8F16-44A5-9120-AD6E1D50EE6A.jpeg 0F6C2FAB-07B7-4F4B-BCDA-3E573B794F1D.jpeg 6B1EC3DF-5D60-4DED-B458-8554F8360878.jpeg Here are some shots I’ve taken of it, cleans up pretty good for black paint
EnanoHemi
EnanoHemi
Umatilla
If it had 3.21 gears how do you go about swapping it to 4.10? Would it just be the final drive at the tune or would I have to open the rear axle?
RedSRT4Me
Scottsdale, Az
2015 CC Sport
Rear axle gear is replaced.
Master bearing install kit.
Gearing of choice. 4.10/4.56 etc
LSD (optional)
Gear oil. 75w140 in the ZF axle.
Diff Cover (optional)
EnanoHemi
EnanoHemi
Umatilla
LSD (optional)
What kind of shops do this? Or is it possible to get it done at the dealer? Sorry for all the questions, I’m just trying to learn and do my research
RedSRT4Me
Scottsdale, Az
2015 CC Sport
I'm not sure where to advise you from there. Good luck!
RLJ10X
Southern Indiana
Enan, if you have 3.92s, you’re good to go.
The difference between 3.92s and 4.10s is only about 4.4%. Not really worth the trouble. If you had 3.21s, obviously 4.10s would be worth your money.
What we’re talking about are the gears in your differential. The bigger the number of your rear end gears, the better “leverage “ your truck has. 4.10s have a pretty big mechanical advantage over 3.21s.
If you simply throw power at a mechanical disadvantage, there is very little to be gained. It like I said, if you indeed have 3.92s you are ready for CAI, Tune, headers, etc.
Good lookin truck btw.
