BLUEBULLY
$719 and Come Silver Ceramic Coated
Not bad at all.
Sent from my SM-N900V using Tapatalk
Not bad at all.
Just ordered my oem 4.10 gears and lsd from Moe's! Also, got a Mag-Hytec diff cover coming! Thanks Matt!!!
Finally getting the gears and diff installed. Any advice on the break in period. The shop is about 25 miles from my home. 4 Wheel Parts Miami Gardens.
If anyone is considering having this done, maybe this will help (not on tech issues, but more on the feel and performance).
Had 3.55 open dif, swapped for oem 4.10 w/oem LSD. Royal Purple gear oil, mini install kit, all new bearings, (tried to install the Mag-Hytec diff cover).
Immediately I noticed the following:
1. Smoother yet, more sensitive throttle reponse
2. Smoother shifts, less shifting all together, no searching for gears
3. A more balanced and planted feel on acceleration
4. More engine breaking, which I like (something I miss about a stick shift)
5. An overall lighter more agile feel to the truck, less bogging down
This is what I was told about the break in period.
500 miles. Take it easy on truck. Don't drive faster than 60mph. Do not drive longer than 10 mintues without stopping and allowing the diff to cool down.
They say the worst thing to do is drive a long distance at freeway speeds, during the 500 miles.
Last, after the 500 miles have it serviced, and have the gear oil changed.
Why the "tried to install the difference cover" Clearance issues?
I had a problem fitting it, but I think I have found a solution.
When's your appointmet?
Check out this thread for more info:
http://www.ramforum.com/f44/4_10_w_lsd_vs_3_55_open_dif_-_gear_swap_review-47205/
On the 17th...next Thursday. After reading your post I'm even more excited! Can't wait. I had head the diff covers had issues with lowered vehicles specifically.
Cool!
I hope my review didn't exaggerate the difference the gears made, and give you false expectations. Lol!
Everything I said is immediately noticeable and a big improvement over the 3.55s and open diff. Plus, I have yet to see how it is after the break in when I can have some fun with it!!!
I am going to MAKE the cover fit when I install the 2/4 drop! If I have to, I am going to grind out a little groove horizontally in the fins of the diff cover, to give the panhard bar a little room to breath.
Who finally did your work? Decent price?
I got lucky and found a differential-4x4-dodge specialty shop in my area. He came recommended from two other shops including 4wheelparts.
$550 and I was amazed at how perfect his work was! Plus, being a mom and pop shop, he let me tinker around with my truck on the rack. I don't get that chance very often!
Even though I only have 6,000 miles on my truck, I went ahead and had him replace the bearings, too. Two reasons: While the diff is open and apart and I am replacing with all new, why not new bearings too. Next, I have heard that it's common they get damaged when they are pulled.
Are you going to be replacing the bearings, too???
Bluebully - Is the gear swap done???
In fairness, properly installing gears is NOT 'straight forward' but getting the work scheduled should be!
You *should* be ok with the install. I would have purchased a 'master install kit' which includes all the bearings, seals and shims needed for install.
Bro it has been a nightmare! 4wheelparts bailed out on me again...After dropping the truck off they tell me that I only had the carrier bearings and needed the pinion bearings. I go through the trouble of ordering them from the dealer to get them to him next day then he calls me and says he will have to reschedule me again! What a joke this shop is...I will never advise anyone to go there and told them I won't be wasting my time with their shop ever again!!! Found a new shop Jeepers 4x4 going this Thursday for the install for the same price. Only question is whether I need shims. He says he will try to reuse the current ones. I have the new oem lsd new 4.10 gears carrier bearings pinion bearings lsd additive and 2 quarts of royal purple diff oil. I hope this is it for the moment. I'm so damn stressed with this upgrade it's ridiculous. Something this straight forward shouldnt be so complicated. Sorry about the long rant!
Unfortunately I got the mini install kit. By no means was I implying that it is simple. Just straight forward in the sense that this is something these shops do every day. You book a block of time and should stick to it. Moreso after cancelling out on me once before, they should have made a little effort to accomodate me. I even advised them that i would be off all the following week...they just could give a ****. That's just garbage customer service. Fingers crossed at this point. Just want to get this done and move on to the next upgrade. Let's hope I found myself a good shop!
So I have a question. With these shops being specialty shops for diffs why are they having you get all the parts needed? I understand that if its cheaper for you to do that but like the extra bottle of RP they should be able to get that and cheaper no problem. Everything from a proffesional shop should be straight forward and should not be putting any stress on you at all and seems to me like 4wheelparts seems like it doesn't want to make money anyways so good on you for not letting them do the work.
