Dubstep Shep
- Aug 4, 2014
- 2,240
- 514
- Location
- Houston
- 2014 R/T
- 5.7L Hemi
Long story short, I noticed some stuff in my cooling system that I don't like. I think it may be from when I swapped my thermostat and the water I put back in. It was labelled distilled, but I'm not so sure it was.
Anyways, I figure once I flush everything out of the system I should go back with a different coolant type that's more compatible than the factory stuff.
Since the system will be getting cleaned out beforehand, I don't see an issue with this as long as I use the correct coolant that's for iron blocks and aluminum heads.
Thoughts?
Thoughts?
