Frame swap
crazykid1994
When I was looking at pulling the cab on my truck I was going to form a brace out of 2x4s to lift the cab and set on them and slide the frame out from under it. Almost like a sawhorse setup
crazykid1994
Also. You may be able to get someone with the proper flare tool to cut and redo the ends on the brake lines? I have a shop by me that does custom lines and fittings.
Edit: my bad. You said parking brake. I missed that
Micchi
Micchi
West Lawn, PA
5.2L
Thought about that but I'd have to turn the truck around or lift it high enough to clear the engine.
Was originally going to lift it with a 2 ton engine hoist and move it onto saw horses.
Sent from my SM-G920P using Tapatalk
02ramboi
live oak florida
4.7 v8
Good job so far can't wait to see the finished product
Micchi
Micchi
West Lawn, PA
5.2L
Had my helpers remove the cab bolts today. Also removed the hvac unit and passenger doors. Looked over everything and I am pretty sure I've disconnected all the wires and hoses that I needed to. Just need some saw horses and I can pull the cab.bd56adbf3ce2ef326fe2376c7634a4a0.jpg10245cf7e841d7fcfecd25ba95293889.jpg
Micchi
Micchi
West Lawn, PA
5.2L
Painted the bottom of the cab and the driver's floor. Have a small rust repair to make on the driver's side rocker0ba0afd587590ff00a182b63edef56fd.jpg5af0638c39e1df4c69cb3c9e64e9ff5f.jpg341c0937ff82d207c455a1f6dca5653f.jpg
Micchi
Micchi
West Lawn, PA
5.2L
The metal clips for the fuel line that runs from the tank to the vapor canister were rotted away. The holes were the perfect size to use some extra bolts and plastic clips to mount the line.
Also mounted the track bar and bracket. Had to drill a hole through the bracket so that I could secure the brake line since the bracket covered the existing hole.
Started mounting the steering box and brace, should have that finished tomorrow and will snap some pics.f6fd20539a875209231d49305b26ab97.jpg67dcefdefc1123f8044b5705617bd0cb.jpgfa3074c1e5087686cb2e70e7cc7eaa29.jpg46da696efad44f6695ccbf40f858cce2.jpg
Micchi
Micchi
West Lawn, PA
5.2L
Got the steering all hooked up and the stabilizer bar installed3b75147c3161dc795dbfd599e20c9608.jpga096fe72f3dea21db5ce9219b36cde77.jpge2eda26387e2076a58a78fd30af7bdbc.jpg345668311363647ee5c8b5a3f593cf92.jpg
Micchi
Micchi
West Lawn, PA
5.2L
Here is the reason I had to stop driving my truck. This little guy fell out again. The first time I paid a shop to fix it without realizing how easy of a fix it was.ddd4dfb379f4b0dd01fb0d3c492f0224.jpg
Micchi
Micchi
West Lawn, PA
5.2L
So I got the engine moved to the new frame on Sunday. Also, managed to break the screen on my phone which is why I was unable to post anything earlier. Have some more parts showing up soon. Hoping to get a lot done over the next 7 days 608eb8818c220c6675f5b9cec0ba425c.jpgc8783b9447eb5037658768637bd6f992.jpg0ac9f8b66522bcad77aa0314f3da4db7.jpg
Micchi
Micchi
West Lawn, PA
5.2L
So I'm debating whether I should replace the head gaskets or not. Already replacing most of the other gaskets. They're not leaking but since I have it ripped apart I figure I should do them.
crazykid1994
If you pull the head gaskets you can see how bad the heads look inside. Maybe give them a quick cleaning with a scrubber or rough sponge and degreaser. Maybe it’s not a bad idea if it’s high enough miles so you don’t have to worry about the coolant ports leaking.
Gr8bawana
6.7 CTD
If it were me I would go ahead and replace the head gaskets and plenum gasket while I had easy access to everything. You should also inspect all of the freeze plugs as well.
Micchi
Micchi
West Lawn, PA
5.2L
How would I determine if the freeze plugs need replaced?
Gr8bawana
6.7 CTD
In your pic looking at the rear of the engine the freeze plug on the left looks rusty. It would really suck to have it leaking after a couple of months with all your work. You can get a kit with all the freeze plugs from RockAuto for less than $15.
In the end the decision is yours.
Micchi
Micchi
West Lawn, PA
5.2L
Got one head off. Cleaning off the old gasket and going to try to clean up some of the build up on the piston.98bb28a89e85fb88b04e283066785a26.jpgd05cf3fd348e4e58bcebf0d9d0843c72.jpg
Micchi
Micchi
West Lawn, PA
5.2L
So the 2 on the back of the block look like they were replaced at some point. Will probably just replace the others to avoid any issues since a few look kinda rusty
OasisNinjaBat
