Torpedoman69
- Jun 4, 2014
- 3
- 0
- 1998
- 5.2
Good afternoon folks. I have a 1998 1500 4x4 that has a messed up front axle when I bought it. (Dana 44 - 3.55 gears). I found a guy with a 1997 1500 4x4 that he was parting out and I bought the front axle from him (Dana 44 - 3.55 gears). My question.....on the 1998 axle the sway bar hooked up to the bottom of the spring bracket and the sway bar has about a 3 inch piece that extends up from the spring bracket. The 1997 has a ~3" bracket that extends up from the spring bracket that the sway bar hooks up to. What gives? Is that the way it is supposed to be? If I need to send some pictures, I can do that. The other puzzling thing is the 1998 steering damper hooks up to a bracket under the passenger spring bracket, but the 1997 front axle doesn't have the same bracket. Where does the damper hook in on the 1997 axle.
I hope I explained this well enough. I am not a rookie when it comes to this kind of thing, but I am new to Dodge Rams.
Thanks in advance.
Rod
Thanks in advance.
Rod
