Gas pump keeps shutting off when fueling. Clean or replace evap filter?
Bighorn_Brown
Army
Check for a kink in your fuel filled hose. Had the exact symptoms you described after getting my Expedition fuel pump replaced. They kinked the hose… fuel flowing from pump faster that it could flow through the hose into the tank.
bluecheese
bluecheese
New Orleans, LA
2021 Ram 1500 eTorque
I had the same problem a couple of years after I began driving my new 2018 RAM 1500. I eventually took it to the dealer and they said it was the vent valve and replaced the entire tank. 4 months ago (140K miles), the problem came back. I found a YT video on this forum where the guy said to run a 3/8”-1/2” hydraulic hose down to the rollover valve on top of the tank to unstick the valve. I only got the hose 1/2 way down the fill neck and hit something hard, maybe the evap air filter? I ran the hose in 6-8 time and hit the same obstruction. Whatever it did worked because I’ve had no fueling issues since. Maybe someone on the forum can tell is what is in the line between the tank and the fill tube?
You ran the hose down the filler neck?
bluecheese
bluecheese
New Orleans, LA
I've been busy, so I haven't had a chance to tackle this problem yet. This weekend I did some googling on the problem, and got a better understanding of what may be happening with the fuel tank and its associated parts. I watched this video Youtube Link and this video Youtube Link
Having watched those, I may take some fish tape and see if I can move the rollover valve, or unstick it if that's what the issue is. May or may not be this week depending on how busy I get.
bluecheese
bluecheese
New Orleans, LA
I haven't had a chance to mess with this yet. But I did pick up some Sea Foam at Autozone the other day hoping that the issue was the rollover valve, and that maybe some funk was causing it to stick. I poured it in the tank, and later while getting gas I had no issues with the pump kicking off. Not sure if that was just a fluke. I'll update after my next fill up.
bluecheese
bluecheese
New Orleans, LA
Took some fish tape and ran it down the filler neck. Once it hit resistance, I started moving it back and forth and heard a click like the rollover valve coming unstuck.
Got gas right afterwards and the pump didn’t click off constantly. Hopefully this fixed it.
mnchopper
Same fuel tank issue? do a search for the above and see how I fixed mine​
Daniel035
Cleveland, OH
RamDiver
Marlborough, Ontario Canada
2021 DS
How large a fish tape did you use, and what about the loop at the end?
The smallest fish tape I have is about 1/4" with a large loop, IIRC.
bluecheese
bluecheese
New Orleans, LA
I believe it was quarter inch.
I grabbed the fish tape from my buddy’s truck. I don’t believe it had a loop. You could probably use a wire hangar too.
Analogkid
St. Louis MO
V6 Pentastar
I bought my 2018 in 2024 and the pump clicking off seemed to just be one paticular station but now it has gotten worse and happens every fill no matter what station I'm at. It has 39K miles now. One Youtube vid stated that if happened gradually it might be the canister filter located on the filler neck. So I'll try a snake or fish tape first and go from there. It seems there is just not one issue that can cause this but several including replacing the tank.
DILLIGAF
Canadian Forces
Canada
the only scenario were you replace a tank if there's a hole in it. Because you can pop out that stupid valve for free.
jws123
nj
On almost every 4th gen i have had the filter clogs on the filler neck with dust you can take it apart and blow it out or just buy a new one very easy fix.
Analogkid
St. Louis MO
V6 Pentastar
That's what I hear. I may buy the updated filler neck and filter canister when it cools off. Sometimes getting the pump nozzle in and out is a PIA.
Clubcar
