Gauge cluster question
TheEnder
4.7L V8
Will this part# 68402203aa 7" evic work on a 2018 ram 1500 4x4 gas 5.7
If it’s a Rev B cluster then yes, it will. Rev B is 2014 and later, if you purchase a 2013 7” Premium cluster you won’t get TPMS readings, as the sensors are different.
Sent from iPhone XS Max
N
NaStY5000
Abbotsford BC
Ok so i received the cluster and everything works except i cant change mileage. I am able to change idle hrs and drive hrs no problem.
Any help would be much appreciated.......
Thank you
TheEnder
4.7L V8
Thank you
If you’re using alfa you could retry a few times, the first doesn’t always work. Are you doing everything completely?
Sent from Blue Onyx
N
NaStY5000
Abbotsford BC
So far i have tried all the suggestions that i was able to find on this subject. I am able to do all the changes just not mileage.
Lildikgang
Houston
I have a 2019 Ram classic express will a 2013 evic work for my truck
tnctx02
2017 RAM SLT
3.6L Pentastar V6
You will want a 2014 or newer. Was mentioned earlier in this thread, TPMS readings will not work, as the sensors are different.
Lildikgang
Houston
I’m not worried about the tpms not reading on it I was just wanting to knowing it will work I’m getting one from a friend for 50$ but wanted to know if it will work if that’s the only thing missing I’m fine with it
Ricks Ram
The 2013 should read the TPMS on the 14 up trucks. I have a 13 cluster in my 14 and it works fine. It's actually the opposite. The 14 cluster won't work in a 13. As long as they haven't changed the TPMS on the 19 you should be ok. The 13 will not show front park assist and may have problems communicating with your radio to display stations ect depending on what radio you have definitely worth giving it a try for $50.
Sent from my SM-G981U1 using Tapatalk
