Jtouch81
So I am currently trying my hand at swapping my 3.55 gears out to 4.10 gears. I’m currently putting everything back together and trying to get the gear pattern and pinion gear correct.
My current pattern is the drive side is on the heel and my coast side is on the toe. I’ve taken out shims and added shims with no luck. I’ve used the old factory shim as well as added all the shims that came in the install kit and am still on the heel and toe. Not sure if I should purchase extra shims or am I doing something wrong?
