getting code PCM P0140
Txhemirt
Lubbock, Tx
Little back ground on truck, catless long tubes and only front two 02s are actually in, the other two in rear are connected but not inserted (zip tied to frame) hemifever tune and ran the truck Sunday. Turned it on today and cel popped up on start up. Any ideas where to start guys?
Ajwalk2008
Springfield, il
Did you have hemi fever turn the rear o2s off?
michaelrc51
NJ
Most likely you have shorted something out it when you zip tied it to the frame.
It has a reference voltage to read how rich or lean it is. The rear 02 sensors aren't for tuning. The code will only come up if it sees a short or open in this circuit.
Txhemirt
Txhemirt
Lubbock, Tx
id put the sensors in and reset the codes
tuned by jay greene
Ordered extensions to do this, hoping it works
From everything I have been told and read, this truck gen has to have the rear 02s even if they aren't plugged in
Hoping this is not the case but with my luck very likely. Will keep y'all posted
Ajwalk2008
Springfield, il
I would contact hemi fever and see what he says
