Guide to Leveling & Wheel and Tire Sizing for 06+ 4wd Ram 1500's
bucsfan8582
Home-Palm Harbor, FL Currently-Spingdale, AR
Bilsteins set at 2.8, 1/4” rough country spacers. 35x12.50r20. Zero rubbing!
Looks good man. I went ahead and got 1/2" spacers just to make sure. saddly i wasn't getting any response here and i needed to place the order. So i'm guessing all will be good.
jon316
I thought of doing the same but the rough country’s were on amazon with one day delivery so I said screw it and tried them. But I would like to get some of those Motorsports ones down the line.
Apiazza
Westminster, MD
Go up to post 399. I posted my setup which is very similar other the difference in offset. I come closest to rubbing on the outside of the tire so decreasing the offset will give you more clearance. You shouldn't have any issues with 1/2" spacers.
crazykid1994
Figured I’d share this here for future reference. Running eibach springs with Bilstein 5100. 3” lift with 1.25” rear lift. 305/70r18 (35x12.5) Mickey Thompson atz p3 on a 18x9 -12 wheel fits with no noticeable rubbing so far. Although the spare does not fit in the factory location
rroche1982
Baton Rouge
EcoDiesel
Question
I have 22" wheels with a +25.4 offset
Running a 1/4 spacer
Tires 325/50/22 which is basically a 35 12.50
Installed tubular upper control arms
Bilstein 5100 set at 2.8
Like this, inside of tires rubs upper control arm very sightly
Will moving to a 1/2 spacer and ET lug clear the tires?
Keithward97
Pennsyvania
Great thread! I have a question and I may have overlooked it in this thread. But I want to run a 35x12.50r20 on the stock rim i will be doing a leveling kit 3 in the front 2 in the rear. What size spacer do you think I'll need to use? I was thinking a 1.5in hub centric spacer. Any suggestions would be greatly appreciated.
Oliver_Closov
SoCal
2016 Ram 1500 Laramie Crew Cab 4X4 w/6.4ft bed
I think it will fit as is. I have 2.6" lift in front and 1.5" Icon springs in rear. I still have 33" on it, but everyone I've talked to is certain 35s would fit without rubbing
jon316
1/4 inch will do fine, it’s what I have
jon316
Thanks for responding. What brand spacers are you running?
Rough country, I’d like to eventually go with some hub centric ones though. But for the price it’ll do for now.
Oliver_Closov
SoCal
I may try that first and just have a set of 1/4 in spacers just incase.
I am on a slight incline in this photo, but I feel like there is plenty of room, although my tires are more narrow than yours.
crazykid1994
2.5 front 1 rear with 305/70r18 (35/12) fits no rubbing but I have a -12 offset which comes out to about 1” out
crazykid1994
Thats a nice lookin truck! Did you recalibrate your speedometer when you changed tire size? If not did it throw the speedometer off by alot?
Thank you. Yes I recalibrated. It’s real easy. I used Alfaobd and just need to know your tires rotation per mile and convert to millimeters and program it in.
TMFMK
