Has anyone noticed a slam/jerk when hitting the gas hard?
Addicted2fishing
Durham region
HEMI 5.7
My wife and I noticed on a trip to Niagara Falls the other day that when I would hit the gas to merge or pass we’d feel like a harsh slam. A hard clunk and it would accelerate normally.
Didn’t always happen. I will admit sometimes I let off the gas and let it downshift and than I’ll go for it. I’m not flooring it by any means here and just normal highway BS. Trying to merge and some A-Hole will speed up and trying to get in passing lane etc.....
My oil change will be in about a month or so and I want to have all the issues I’ve experienced since last oil change looked at all at once
Thanks for any info [emoji106]
Mods: EGR matte black bug deflector, Westin HDX drop steps, rough county bull bar with 20” LED, custom made NW seat covers in real tree camo, husky liner mats, husky liner mud guards, undercover LUX tonneau cover, Tailgate assist, flowmaster super 40 with resonators, tinted 15% front, LED C shaped tail lights.
huntergreen
Marine Corps Navy Badge
Can't say I have noticed this. I would suspect the trans though.
O.R.T.
Wessyyydddeee
Transmission shifting error.
Transmission mount.
Motor mounts.
averageguy
Belleville Mi
hemi
Do you have a 36 gallon tank? some people say the fuel sometimes sloshes to the rear on hard acceleration if you have 1/2 a tank or less and makes a thud sound and they feel a bump. If you decelerate or brake then hit the gas it increases the effect. On a larger scale I have pulled tankers with no baffles and a 10,000 tanker half full can feel like the brakes locked up when accelerating and it hits the back of the tank, and like being rear ended hard when braking and the load sloshes to the front.
Addicted2fishing
Addicted2fishing
Durham region
HEMI 5.7
No just the regular 26 gallon tank
shadowhawk
Southeast WI
hemi 5.7 with I2 tune
I've had what I consider a "slip" in first gear only. Never in any other gear.
Casper
U.S. Navy (Ret.)
Springfield, VA
5.7L
I get some funky shifts in stop and go traffic; mostly weird downshifts, but nothing like you've described under acceleration.
FXCLM5
2017 Laramie CC
ED 3.0 V6
I can produce this bump on command. Anytime you coast downhill and then want more speed (traffic) this happens.
It happened 2-3x on my last road trip. Everytime it was coasting downhill then accelerating the thing hardshifts bumps then goes. Mine is physical the truck shakes/lunges from that bump
ColdCase
No harsh shifting otherwise? Harsh shifts are usual an internal leak that screws up adaptation values. i.e. the transmission increases hydraulic pressure to compensate for the leak which causes rough shifting otherwise.
The second gen 8speed has a coast feature used to save a tiny bit of fuel. If FCA enabled it, it can be slow to disengage because the adaption is off.
Jrod
USAF 1997-2008
Virginia
2025 Laramie
SST SO
Mine just likes to be jerky when it down shift into first gear coming to a stop... but not always...
Addicted2fishing
Addicted2fishing
Durham region
HEMI 5.7
Thanks folks! Keep the responses coming! Gives me more to discuss with dealer
TRCM
USN, Retired
Newport News, VA
2012 1500 Laramie CC 4x4
32 gallon.......not 36
And it's 1/2 to full tank when most notice it.......on mine, it's most noticed in the 5/8 to 3/4 range
FCA Master
West Texas
Keep in mind this is an 8 speed transmission. When you do a hard kickdown event you may be dropping several gears which is a pretty severe gear ratio change.
Ramm5.7
So Cal
2019 Ram 1500 Classic Bighorn
Driveshaft slip joint maybe? I had a similar thunking after first buying, turned out no lube on slipjoint caused a thunk on downshift to first. Sometimes it was coming to a stop at light then when releasing brake and accelerating i would get a thunk. Like a bad u joint or gears. Dealer replaced shaft
Addicted2fishing
Addicted2fishing
Durham region
HEMI 5.7
Well, it’s funny you say that. When I first bought it I noticed when going from drive to reverse or vice versa it would clunk pretty hard. You can feel it and hear it. Took it to dealer they said normal. So I left it. It’s doesn’t always do that but when it does I know. It’s weird. If it blows the driveshaft it’s on record I complained about it
Sometimes I worry I got a lemon. I’m just crossing my fingers it’s just little oddities that are harmless. She’s gonna have to last me a while
Ramm5.7
So Cal
The SOBs always say/try that "normal" crap. Sometimes you gotta grab em by the earlobe, "get in my truck" and show em what normal IS NOT SUPPOSED TO BE
TRCM
USN, Retired
Newport News, VA
That is the standard answer, hoping you will buy it and leave. If it is your 1st full sized truck, maybe, but if not, then if it is different enough for you to notice, it is likely not normal. Stay on them about it. My dealership use to always tell me the same thing, it's normal, till they got a new service manager for my team, and now, he seems to listen to me, as he has learned when I tell him something is wrong, my track record is 100%, even when the previous dude told me it was normal.
I think they are taught to say this so you will buy it, then you get use to it, and no longer notice the noise. So when the part actually breaks, you are out of warranty, and the repair bill is on you.
Fat fingers, bad proof reading. Yes, 32 gallons.:)
Ha...can understand and relate to both...........
RamCares
n/a
n/a
Hi FXCLM5,
This is not what we hope to hear from our customers. We understand that you are just sharing your experience with other forum members at this time. However, if you do choose to visit a dealer to have this diagnosed further, we would like to offer our assistance as well. Please feel free to send us a private message with additional information.
Julie
Ram Social Care Specialist
Mineralram
I had this issue up to about 5-6 weeks ago when my dealership told me I needed the update for pcm and Tcm has been gone ever since
Nicholas Lozano
