Heated seat control tweak with alfaOBD
Joshua Brown
Georgia
I know alfa OBD can do many thing . I want to tweak the temperature that the heated and cooled seats come on. I believe the stock set point is like 45 degrees and 80 degrees. I want to adjust it to like 60 and 70. Is this possible?
2012Lamarie
Love to do the same. Following
Administrator
I've not read about anyone finding or changing the auto-on comfort temperature set points, it's most likely hard coded into the HVAC or Heated Seat module.
Ricks Ram
As stated by crash68 these settings cannot be changed with the Alfa tool. They are pre set to come on at 40° heat and 80°. Vent.
Sent from my SM-G981U1 using Tapatalk
N8sBrewing
Orange County CA
Possible related question.
Defaults:
Heated comes on high setting = ok
Cooling comes on low setting, can this be changed to high?
Administrator
@N8sBrewing that would also be a negative on the seat cooling starting on high.
NachoImperium
Germany
Hey,
I know it's a bit late, but you can set it via AlfaOBD, do you still need the info?
