So I have an 04' 1500 Hemi. 62,000 miles. I recently had the fuel pump replaced. The 1st time I filled the tank, the check engine light came on(ran fine). After 25-30 miles it went off. It ran fine until a couple hundred miles later when it acted the same as when the fuel pump went out. Could I have a bigger problem?...if so where do I start looking. I will soon get it back to my mechanic to check it out and read codes.
Thanks.
Sent from my VK815 using Tapatalk
Thanks.
