Help paint bubbles
Bee1971
Sobieski WI
2011 Sport 4x4
345 Hemi
In that link I posted
After the fact
Some of those pictures I posted is the actual adhesive
These front fenders are so damn thin , they BOND that patch on the backside of the fender to strengthen the intregity of the fender itself
It is not a sound deadener
If you run your hand over that adhesive patch on the backside you might find some soft spots or bubbles - That's where they missed the adhesive when applying and its basically air pockets within the material
When you buy a new fender from Mopar
Guess what
They come with these adhesive strengthening patches already pre installed on the backside
Do not try to remove unless you enjoy destroying your fender
S
skirider
After the fact
Guess what
Ok thanks is it a big job for a body shop to replace fender or is it all bolts.
I xan only imagine the head ache if i try to have my ziebart rust proofing cover
Bee1971
Sobieski WI
2011 Sport 4x4
345 Hemi
I can guarantee any rust proof shop did not remove the plastic wheel well liners before rustproofing or spraying
That would bee to much labor cost
I would have removed all four of them myself before sending off to any rustproofing shop
Most of these rust issues are behind the plastic wheel well liners
What's your warranty state through Zeibart ?
Fenders are easy to replace
It's the rockers arm panels and rear quarters that are spot welded in place
S
skirider
Ziebart waranty states has to rust through from back side and the dont cover caulked or foamed areas. Thats the fine print and i have a feeling that will be there out.
Im gonna get an estamate to replace this weekend maybe and go from there.
