Help!!! Projector wiring?
cmiller0711
Millington TN
Just hooked up my lights which are duals and they work! Only problem is they only work on hi beam (the hi beam door is opening) low beam does nothing....
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
what harness do you have for your HIDs?
cmiller0711
cmiller0711
Millington TN
Ok that fixed my problem now everything works great when the truck is off but if it is running and i put it on hi the relays make an awful chatter noise
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
it sounds like your truck is wanting to turn off the highs. so the chatter is the high beam solenoid going nuts, raise, lower, raise, lower.
who's wiring are you running? heavy duty doesn't really tell me much. LOL
cmiller0711
cmiller0711
Millington TN
It is the trs bixenon all grounds are great I'm thinking of running caps on it
cmiller0711
cmiller0711
Millington TN
It is for sure the relay it makes the sound with no lights hooked up at all
cmiller0711
cmiller0711
Millington TN
4700uf cap between the low beam and ground fixed my problem!! They work great now
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
cool
