Help rear window leak.
Mopar03
My 99 Ram rear window has a water leak. I first thought it was the third light, but it was not. I called a local glass shop and they told me they can pull the glass and reseal it. The bad news is they told me I have to buy a new piece of glass just to get the black trim that goes around the glass. Does the trim seal the glass, or is the window glued in? They want $240 out the door for glass and trim piece. I called a local dealership and they confirmed they don't sale just the trim. I thought about running silicone around the glass to fix it. Has anyone been thru this? How did you fix it?
dapepper9
Iowa/Nebraska Border
5.9L V8
I would imagine you could use some silicone around the edge and that it would hold up just fine. Might not look pretty but should work. Something I would do anyways lol
Merc225hp
NA
truck
gas
Silicone, no I would not go that way. More like a marine caulking for underwater use. Look for " life caulk"
M
Mopar03
A body shop told me they had some that is used for sealing Windows. They would do it neatly for $20.00. I'm probably going that route.
