HID Problem
fuzzie
Just install 55w hid's from the retro shop, followed the instructions,cleaned and greased the grounds. Works great until I turn the radio on to fm, nothing but static,turn the headlights off and the fm is clear again, on xm it's fine. By the way,It's a 2010 Bighorn and I put the low beam Hid kit in.
Any ideas?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
just replied to your email there
Most of the time on these it comes down to a weird ground. Though I think I just got the answer to the question I just sent you.
So, you made your own grounds, sanded it down, cleaned and greased, all done. Not using a body ground or fender bolt, etc - correct?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
I always make my own grounds. Anywhere close to the ballasts, drill a small hole somewhere, sand down the paint, put some dielectric on it, use a self tapper to put the ground in.
