Horn not working
Terry Gideon
I used the horn once and it made a sound for a split instant and now no sounds. I can run a wire from horn to battery and it sounds off but not when I press the steering column. Replaced black 5 prong fuse under hood, still nothing. Any ideas?
96Rammy
California
5.9L Magnum V8
Okay, the 5 prong box is called a relay. Did you check the actual fuse? It should be in the same fuse box you found the relay. If you're standing against the fender looking down at the box, it is the 2nd one from the top on the far right. Should be a 20A fuse. That would be my guess.
Terry Gideon
Terry Gideon
Thank you, I found it and that was the problem. I thought the relay was the only "fuse" but was wrong, many thanks again!
