How To: Add Factory Keyless Enter N Go
skuppy069
canada alberta
2018 1500 cc
Yes sir luckily it was the C5 connector on the BCM that I had unplugged hoping to get more room. When I had wrapped everything up last night I pulled on the connectors to make sure they were latched but I had unlatched the C5 connector and re-seated it. Jimmy07 saved me today by recommending that I reseat the connector after he ask if I had unplugged any other connectors. I GREATLY appreciate how helpful everyone has been on this forum!
17' CCSB 4X4 68RFE 2500 6.7 Tradesman DRP EGR delete, CTT tuning w/TCM tuning, UAQ w/7 speed HVAC, 7" premium EVIC, OEM front Parksense, OEM style front camera, aux switches, OEM remote start, Single Zone ATC
Yep it’s a great resource
Hanover Fiste
NW Florida
2005 SLT, 2018 Sport
I finally got Keyless Go to work! After receiving a reply from the developer this morning, it turns out I had the "Interface Timeout" setting set too high. It needs to be set to 100 mS or less; mine was set to 400.
All this was done on a 2018 Sport, using the Windows version of AlfaOBD, and using RF Hub 68363199AC.
Veritas726
Man what a journey. Glad you got it up and running.
bigdodge
Has anyone had the wiring for the RF hub and antennas already there? Just not in use. I just checked mine and I have the c2 plug and one for the antenna already there unused.
Sent from my Pixel 4 XL using Tapatalk
Ricks Ram
What trim level is your truck? If it's a Laramie it may already have some or all of the factory wiring which would save a lot of time and money. We have done several of these conversions but they have all been lower trim levels and didn't have any of the factory wiring. We are getting ready to do a 15 Laramie 2500 soon and I am hoping it has some of the wiring as well.
bigdodge
It's a 2015 power wagon. It's not fully loaded out but it appears to have the necessary wiring. Where would the front antenna be? Under the center console?
J
Jimmy07
I would guess your body harness has the provisions for the two cab antennas and the wires going to the four door cab side connectors, but you probably still don’t have the wiring on the door sides of the door connectors. Pull the lower B pillar panel and check to see if the door antenna wires are populated on both sides of the door connector.
bigdodge
I'm still waiting on my RF hub and was just looking around. I'm sure you are right. I have all the necessary wiring harness parts so I'm not worries of it's not all there. Hopefully I can just get the push button start hooked up without much trouble
Hanover Fiste
NW Florida
Find keyless go, passive entry, fobik safe enable, and passive entry CSM, and enable them all.
Which of these can I disable if I'm not going to add "Keyless Enter," without affecting "Keyless Go?"
Hanover Fiste
NW Florida
Thank you!
Edit: I believe those two parameters DO affect Keyless Go. I disabled both of them via AflaOBD, and the "Press Brake Push Start Button" on the cluster disappeared, replaced with "Key in Ignition."
I enabled them back, and the cluster returned to normal.
48PowerWagon
Bellingham, WA
As I'm waiting for my parts to arrive (any1 making antenna rigs? (harnesses)) I'm prepping my rear seat area (rear seat hook mod) and cleaning I noticed my body vents (68324094AB Exhauster-Bodyside Aperture) missing flaps and broken grills so I order a couple replacements (only 10 bucks @ allparts) so besides loosing up my bed and pulling back an inch or two how do I remove and replace?
bigdodge
I replaced mine from inside the cab. Very tight and a little soap and water helps.
bigdodge
J
Jimmy07
If you unplug that connector, is there a male pin on the other half of the connector that wire would mate to?
bigdodge
There is a wire going through to the door. If that's what you mean
bigdodge
So does anyone know where the factory front antenna location would be? If I have the back antenna wiring I should have the front just not having any luck locating it.
J
Jimmy07
Underneath the jumpseat/center console between the driver and passenger seat. It bolts to the same bracket that the ORC module is mounted to.
bigdodge
That's what I thought I had read in here somewhere. Just wanted to clarify. Hub should be here Monday and I'll be ready to go. Thanks for the help
