You get it to snap on ?Has anyone ran into an issue of not being able to get the driver door wiring harness connector to lock back into the cab? Any suggestions, tips, or tricks?
I've tried to get it to lock in w/ the rubber boot on and with it off.
I'll message you my VIN 18 Laramie CC:Anyone have the part numbers for the painted passive entry handles in Gloss Black (Plain Black, not the Crystal Black) Paint code PX8.
-K
I'll message you my VIN 18 Laramie CC px8:
Edit nevermind.... Mine is brilliant black crystal.
M² Mods.
...Only issue on this side was not being able to get the driver door connector to snap back in place.Passenger side unfortunately does not work. I *think* it may be because of a poor connection at the passenger door antenna.
But honestly, as much as I had this truck taken apart and all the work I got done and finally getting it all back together, I didn't really care all that much haha. Maybe I'll look into again after I get back from work in a month.
Does the antenna check in Alfa work? I thought I read even when all was working correctly, antennas or door handles read "not ok".
Thanks Jimmy and everyone else providing information on this project.
What items are you after ?For anyone who has done this mod, do you have any of the bulk terminals/connectors left over that you are willing to sell. It looks like Nexus is on to us as the minimum amount for those bulk items has been increased.
thanks,
matt
As far as the door handle connectors go if you where ok with just using a two pin molex connector instead etc@skuppy069, I haven't gotten anything yet but I figured I'd see if anyone had leftover of the ones that can only be purchased in bulk. From what I can tell, it would be these:
Antenna Connector Terminal - 1355717-1 (Cut Strip), need 12 (only sold in min qty of 100)
Door Handle Connector - 7283-6079-30, need 2 (only sold in min qty of 20)
Door Handle Connector Terminal - 7116-4720-02, need 4 (only sold in min qty of 100)
I am a little confused though because I believe on page 75 member 'Remen' mentions some additional parts (7114-4112-02 and 7116-4112-02) so I don't know if those are needed as well and in what quantity or if something on the page 1 parts list is incorrect. Any guidance on that would be greatly appreciated as well.
Thanks,
Matt
