DoughRat19
- Oct 6, 2020
- 321
- 186
- Location
- Massachusetts
- 2019 Classic
- Hemi 5.7
So it never told you the fob finished programming? You could have a problem. Might need a new fob.
Can you delete that fob then reprogram it .Is the truck in the Run position?
If the lock and unlock worked then it means it’s still programmed to the hub .I unplugged the hub and plugged it back in and the fob was no longer programmed to the hub. I tried to reprogram the fob but it hung again even though the lock and unlock worked. I think it's either the fob or my cheap Chinese obd scanner. I'll start with another fob from amazon.
Did you delete the fob with alpha when connected to the rf hub ?
Are RF modules vin locked? I found a good deal on a used take off vehicle, however I wasn't sure if it will work on other vehicles with or without extra cost.
It could easily be a problem with the scanner too.Nope, Just unplugged the hub and plugged it back in. Fob no longer worked so I tried to pair again. Same thing. Fob pair hangs but lock/unlock works but when trying to run the reset hub process it says fob not inside truck.
Select erase fobik? That option scares me. I don't want to erase my working keyed fob. I want a second remote anyways as a backup.Like skuppy said, you have to delete it in alfa then try to program it again.
Correct his existing fob would be linked to his old rf hub .someone can correct me if I’m wrong but your original remote will not work with the new RF Hub. I haven’t done the erase procedure but I assume you have to let it know what fob you want to erase by pushing the unlock button on it or something. Similar to how you tell it which one you want to program.
wondering if anyone has tried the B pillar placement idea I read earlier for the passive entry antennas?
got most all my parts on order I think I need the other RF hub (68363199AC)
I have 68363202AC
been playing with AlfaOBD so I am confident I can mash this up in a spectacular way!
