How To Add Heated/Ventelated seats and Heated Wheel to Express/Tradesman
cptwing
The Soviet State of Connecticut
2014 3500 ST DRW REG CAB
6.4l Hemi
I just picked up my truck a few hours ago and just loaded the CD have not plugged into truck yet. Is there anything I need to download, or do I just plug it in?
DeereGuy
Pittsburgh, PA
Adding Heated/Ventelated seats and Heated Wheel to Express/Tradesman
Did you activate the enhanced option? The code should have been in an email from KT.
Besides that, just have the obd2 plugged in and the cable plugged into the computer before you launch the software.
WilliamS
Tampa FL
I never got an email with any activation code it says that the code is preprogramed into the proline vci connector?
I haven't either. So I was kinda curious about this. It seems we are on the same step.
Sent from my SM-G935T using Tapatalk
CuylerTech
NH
2015 Big Horn Mega Cab 4x4
6.7L
It is. Have USB plugged in then start the installation.
DeereGuy
Pittsburgh, PA
Open the software. Go to help and then feature activation and see if the Chrysler feature is activated.
cptwing
6.4l Hemi
Rick Deere or Rt I know it's late but a quick phone call would really help if you guys don't mind
WilliamS
Tampa FL
Post results if it was activated already please. Will help me Monday before I call cussing Someone out
DeereGuy
Pittsburgh, PA
Mine did not come pre activated. I had to activate it with a code sent to me by KT.
69mach1
Cummings 6.7
That's pretty bitchen and gives me hope this is going to fly in my truck :favorites13:
So I cleared the dtc's and that didn't make a difference. The physical button acted the same. I could press the radio button, it would stay on for a few seconds and then turn off. I marked it present in ECU 5 and just like the vented seats it started working. So as of right now, everything works on my truck. Since it is below 40 here, the seats and steering wheel now kicks on automatically when the truck starts.
I can't figure out how to get the comfort settings on the radio, but that doesn't really matter to me. I still have some dtcs listed in the CSWM, but it says that it hasn't been tested since last clear, so hopefully they will go away soon. I'll check back in a few days. Regardless, did I mention everything works now!!!!!! :)
DeereGuy
Pittsburgh, PA
It is 8 degrees here this morning. Man the heated seat and wheel are nice. I would have never guessed I'd like it this much lol
WilliamS
Tampa FL
Show off. I looked for my code, I don't have it. I guess Monday when it gets here I'll be on the phone.
Still gotta figure out how to get it going with remote start.
Dodgetk81
I've almost got my wiring ready to go. I plan to tackle next Sunday. My plan is to run up to the pdc. Just doing the seats for now, but I'm running the wires for the wheel. Still have to get the clock spring.
cptwing
6.4l Hemi
Mine was in my junk email from Dylan Smith
cptwing
6.4l Hemi
I got the software activated was able to run check for DTC codes, but cannot figure out where to go to mark things present? I looked for the play by play that RT put out but cannot find it.
My goal was to enable the mirror, get the compass and temp in the Radio and maybe get the CD player working again. I did have a DTC for the CD player "lost communication with the radio", it was late not sure where to go from here. Please advise
00R/T
CT
After it finds the VIN and you connect, you want to pick the BCM from the list of modules. Once you're connected to the BCM, one of the tabs is like "onboard tests" or something. It's like the third one from the right. Under that you pick "module configuration" from the dropdown list.
DeereGuy
Pittsburgh, PA
After you connect to the truck, pick the "Body Control Module" from the module list. Once it connects, go over to the "Test OnBoard System" tab and pick "Module Configuration" from the dropdown. You can then navigate all the options using the 3 buttons on the top right (you can't navigate the list directly with mouse or keyboard). The setting you want is under ECU 3. There is another under "Memory", but I've never touched the ones in there.
Something interesting to note. The settings in the BCM on mine have them off, but if I read the status from the CSWM it has vented front seats and heated rear seats enabled. This is nothing I set and nothing I can see how to change.
Here you go cptwing
