How To Add rear Park assist
S
skuppy069
canada alberta
2018 1500 cc
No idea what correct harness is. You don’t have to say you’re sorry your diy has been a great tool for my install. Splicing a waterproof connector on the jumper took all of 15 minutes and that’s doing both sides. Thank you sir for your great write up.
Thanks for the kind words .
I will track down the connector part number this week and update here .I hope your install goes well for you .
Cheers
S
skuppy069
canada alberta
2018 1500 cc
I think this is the connector .
I will order One tomorrow and confirm hopefully this weekend .
68068660AA
SHERMAN ROBBINS
Dallas
Has anyone ever ran into the problem of no volume after the install? Everything else seems to work just no volume I've checked all the settings did I miss turn something on bcm?
S
skuppy069
canada alberta
2018 1500 cc
Did you Enable the csm for Volume and is checked on in the radio settings ?
S
skuppy069
canada alberta
2018 1500 cc
So you should have
Park assist type rear or front/rear is doing both front and rear
PTS configuration
Ultrasonics
PTS
Then the park assist volume csm rear
Then park assist volume front if you did the front as well
SHERMAN ROBBINS
Dallas
So you should have
PTS configuration
Ultrasonics
PTS
Then lake assist volume front if you did the front as well
I did the rear only
PTS configuration
Ultrasonics
park assist volume rear
YOU HAVE PTS I don't recall a setting that said only PTS!!! Do you happen to know where in alfa it under?
SHERMAN ROBBINS
Dallas
Still no sound will have to retrace all my steps tomorrow im missing something!! thanks again for your help
S
skuppy069
canada alberta
2018 1500 cc
Ok no worries .If we still can’t get it working maybe we can make a phone call and compare bcm over the phone tomorrow to see what is missing etc
SHERMAN ROBBINS
Dallas
Started my truck this morning everything worked including the sound. I'm guessing one of the modules in the bcm just hadn't updated. THANK YOU AGAIN!!!! Your help was most valuable!!!!
S
skuppy069
canada alberta
2018 1500 cc
Grad it’s working .
No worries glad I could help out .
Cheers
ChloeBrooks
