SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Any ideas on the "device not supported" message I'm getting everytime the radio powers up?
I updated from a factory 5.0 to a UAQ. Bought it new from Benny. Also did the 4 to 7 spd blower conversion as well as the single zone auto temp conversion. I added the sun sensor for atc harness and the 4 pin sun sensor. Everything went well except two issues.
I get a "device not supported" window everytime the radio powers up. It doesn't go away until you click ok. First I thought it was because I haven't installed the updated usb hub. So I did that tonight and no change. I still get the message. No phones paired. Nothing connected to the usb ports or aux. No fault codes in the radio either. Kinda disappointing after the money spent to get an in your face issue everytime the radio powers up. And you can't find out what device it's referring to either.
The other issue I have is a fault code in the HVAC. I don't recall the code but it's for the right side blend motor. It's setup for single zone ATC, so it shouldn't look for a passenger side blend motor. Fault only goes away if I revert back to single zone manual. Is this an expected fault that everyone gets? Would it effect the system operation? Any way to eliminate the fault?
View attachment 244646 View attachment 244647 View attachment 244648
Specs
2018 Ram 3500 tradesman. Diesel. Factory back up camera. Factory 5.0 and sat radio. Factory rear parksense.
Harnesses I bought from mp grimm. Everything else Chrysler, Benny.
Thanks,
Earl
Try this...
https://www.ramforum.com/index.php?posts/2495436
CoZo6
2021 Limited Longhorn 1500
Douglas County, Colorado
5.7 eTorque
What exact panasonic radio PN/model are you using?
And do you know what application version the radio is running?
M² Mods.
(via Tapatalk App)
Ezduzit23 has my UAQ, it is Part 68331631AJ and here is a screen shot of what it had when I sent it to him. I don’t know if he has done any other upgrades. I did the 22.6 along time ago: upload_2021-4-30_15-36-39.jpeg
Avh5153
Washington PA
Ok guys, I have a weird issue here.
2013 Ram 2500 Laramie G56
It came factory with 8.4 Uconnect with Navigation and dual zone. I recently upgraded to a UAQ radio thanks to Deereguy hooking me with up with one.
When I initially fired the truck up the climate works no issues at all. After it sits for a while and the backup cam and SXM enable is where my HVAC starts giving me issues. It only displays on Hi or Low. No temp in between. If I pull a battery cable it will start working again until it sits a little while. I recently discovered that changing my units to metric makes it work just fine. But then I’m in KM and what not. I did the temp module to 2018 version upgrade and that changed nothing. Any thoughts? @ManualCummins suggested a software update to 22.6 which I will be doing next. I’m on 19.9 right now.
chri5k
USA
Diesel
Where did you get the upgrade kit? Whose harness do you have? There some harnesses / kits that seem to have more problems than others.
Avh5153
Washington PA
My truck came with dual zone and 8.4 from the factory. I’m just upgrading to 4C. The only harness that I added was the infotainment harness to enable my heated and cooled seats in the menu on the radio.
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Did you install a new or used 2018 HVAC module with your 13ram2500 g56? (xxxxx553Ax)
I doubt an sw upgrade of the radio to v22.6 would help and don't recommend it as v19.9 is the better version imo.
If you have AlfaOBD, try this with you factory dual zone atc setup....
RESET YOUR HVAC Configuration:
Connect with AlfaOBD and set your truck (Ecu Config 3) HVAC Configuration to: Single Zone MTC
Then disconnect AlfaOBD, Shudown the truck, let it go to sleep… and pull the 20A inline Radio fuse near the brake booster at the firewall (2 minutes) to force a radio reset.
Next… Get back in and switch the truck to “run” without starting. Wait for UAQ to reset… it’s done when the SXM button appears and the Backup Camera works again. *** You must wait for the reset to finish before proceeding **
Check the HVAC on screen menu… it should show the Single Zone temp slider without the temp readout .
Next...
Set Dual Zone ATC:
Connect back up with AlfaOBD, HVAC Configuration back to: DUAL ZONE ATC
Then disconnect AlfaOBD, Shudown the truck, let it go to sleep… and pull the 20A inline Radio fuse near the brake booster at the firewall (2 minutes) to force a radio reset. (yes again)
Check the HVAC on screen menu… it should show both Dual Zone ATC Temp sliders with the temp readouts.
You should now be back to your original factory dual zone ATC setup.
Avh5153
Washington PA
Next...
Set Dual Zone ATC:
Thanks a lot! I’ll try this tomorrow and report back.
Mpgrimm2
SC
5.7L
And disconnect that 4c Infotainment Seat Interface harness/Module completely until done with the HVAC config changes and you know for sure if it's affecting the function of the temp blend door or not... ie a full day or two after your done.
Also: are you running a new or used 2018 Ram 2500 hvac module (xxxxx553Ax )??
M² Mods.
(via Tapatalk App)
Avh5153
Washington PA
M² Mods.
(via Tapatalk App)
I’ll do that as well. I’m doing the change right now so if it doesn’t work I’ll unhook the infotainment harness and repeat. I’m running a new unit 68366553AA.
Avh5153
Washington PA
There was no change after doing the HVAC reset. I tried it with and without infotainment harness connected. One thing I did notice was the actuator behind the glove box changed when I changed temp when it was on MTC. One other thing I thought was strange I noted in my original comment is it works like normal in dual ATC when I change the units to Metric.
Any other thoughts?
Roman217
Metro Detroit, MI
Any other thoughts?
Can you post your BCM settings? I know my HVAC contros freaked out when I had the CSMs for other measures/units (power units, temp unita, torque units, etc) turned on. After I turned all those off and only set the US/metric CSM my controls returned to normal.
Sent from my SM-N986U using Tapatalk
Avh5153
Washington PA
Hardware Supplier Identification: Continental
Software Logical Block Supplier Identification: Continental
Active Diagnostic Status Of ECU: Running in Application mode
Gateway: Yes
Vehicle Configuration Programmed Status: Yes
Last Programmed Status: Manufacturing
ECU Qualification:
Sense-Ambient Light Dimmer Wheel: No
Sense-Reverse Switch: No
Sense-Door Lock Switch Front Driver: Yes
Sense-Door Lock Switch Front Passenger: Yes
Sense-ERS Switch: No
Sense-Flipper Glass Ajar: No
Sense-Fuel Level Sensor #2: No
Sense-Hood Ajar Switch: No
Sense-Hard Top/Stealth Input: No
Sense-Liftgate/Trunk Ajar: No
Sense-Trunk/Flipper Glass Release Switch: No
Sense-Rear Wiper Park Switch: No
Sense-Washer Fluid Level: Yes
Sense-Flipper Glass Release/Sunshade Switch: Yes
Sense-ESP Off Switch: Yes
Sense-Cargo Lamp Switch: Yes
Police Passenger Unlock Motor Present: No
Control-Headlamp Leveling: No
Control-Baggage Comp Lamps: Yes
Control-Diesel Cabin Heaters 1-3: No
Control-ESCL: No
Control-Diesel Fuel Heater Relay: No
Control-Flipper Glass #2: No
Control-Foot Well Lamps: Yes
Control-Front Fog Lamps: Yes
Control-Headlamp Washer Motor: No
Control-Passenger Airbag Off LED: No
Control-Rear Fog Lamps: Yes
Control-Rear Turn Lamps: No
Control-Rear Wiper Motor/Flipper Glass #1: No
Control-Run/ACC Relay #2: Yes
Control-Side Repeaters: No
Control-Sunshade: No
Control-Trunk/Flipper Glass Relay: No
Control-UGDO Feed: Yes
Control-Trailer Tow: Yes
Control-Dedicated DRL: No
Control-VTA Indicator Request: Yes
Control-Passenger Airbag LED: No
Adjustable Pedals Present (Non-memory): No
Inverter Present: Yes
Intrusion System Present: Yes
Remote Start Present: No
Tip Start Present: No
HID Headlamps Present: No
Auto Headlamps Present: Yes
Rain Sensor Present: No
Remote Compass Present: No
EC Mirror Present: Yes
Cruise Feature Present: Yes
RKE System Present: Yes
SKIM System Present: Yes
Police Vehicle: No
Military Lighting: No
AC Present: Yes
Rear Doors Present: Yes
Electronic Shifter Power Feed Present: Yes
____________________________
Car configuration
VehConfig 1:
___________________
Model Year: 2013
Vehicle Line: DJ - RAM 2500
Country Code: USA
Left/Right Hand Drive: Left Hand Drive
Drive Configuration: Selectable 4wd
Emode Present: No
Auto Highbeam: No
Body Style: 4-Door Pickup
Maximum Vehicle Speed (0 - 500km/h): 510.000 km/h
Shifter Type: Not Applicable
PTS Display Type and Location: Headliner or NO Display Programmed
Performance Pages Present: No
Special Package: DT Base/Sport/SLT+/Laramie
Headrest Present: No
UREA/SCR System Present: Yes
Auto Park Configuration: Not defined
Rear View Camera: Yes
CHMSL Camera: No
Hill Descent Feature Present: No
Select Speed Control Feature Present: No
VehConfig 2:
___________________
Power Inverter Type: Latching Switch
Thatcham Present: No
Run Flat Tires Present: No
Maserati Vehicle Mode: Normal
Passenger Airbag Disable Switch Present: No
Air Conditioning Present: Yes
Cruise Control Present: Yes
Flipper Glass Present: No
Full Size Spare: No
Off-road Capable: No
Special Package: No Package
Dual Rear Wheel (DRW) Vehicle Present: No
Non-Regulated Tire Pressure Information System: No
Max Load Inflation Pressure Rear Tire (0-126PSI): 50.000 PSI
Max Load Inflation Pressure Front Tire (0-126PSI): 50.000 PSI
Light Load Inflation Pressure Rear Tire (0-126PSI): 45.000 PSI
Light Load Inflation Pressure Front Tire (0-126PSI): 60.000 PSI
VehConfig 3:
___________________
Police Lighting Feature: No
Power Lift Gate Present: No
Power Right Sliding Door Present: No
Power Left Sliding Door Present: No
Sunshade Present: No
T-Case Type: Transfer Case BW 44-46
Wheel Base: Long wheel base (140'' & 149'' Ram Truck)
FOBIK Safe Enable: No
ELV Present: No
Fuel Capacity (36-290 L): 117.000 Liters
Window Express Feature Configuration: Front windows express only
Adjustable Pedal Feature Present (non-Memory): No
Auto Headlamp Feature Present: Yes
Door Alert Feature Present: No
Two Fuel Sending Units Present: No
Vehicle is an SRT: No
Disable Display of Radio Clock: No
Chassis Type: Type 13 /(SDB + BR2 + DJF + DSE)
Display Outside Temperature Present: Yes
HVAC Configuration: Dual Zone ATC + Rear
Vehicle Brand: Ram
Display Compass Heading Present: Yes
Interior Electrochromic Mirror Present: Yes
ESCL System Present: No
High Intensity Discharge Headlamps: No
Secondary Lock Present: No
Liftgate/Trunk Type: Trunk
Collision Mitigation System Present: No
Forward Collision Warning Present: No
Base TPM System Present: No
Premium TPM System Present: Yes
Paddle Shift Feature Present: No
Sport Mode Present: No
Auto Park Present: No
Passive Entry Present: No
Keyless Go Present: No
VehConfig 4:
___________________
Transfer Case High Ratio (0-16.382): 1.000
Axle Ratio (0-65.534): 3.420
Transfer Case Low Range Reduction Ratio (0-65.534): 2.640
Dynamic Tire Circumference (All or Rear) (0-65534 mm): 2730.000 mm
VehConfig 5:
___________________
Luci Feature Present: No
Equipped with Variable Geometric Turbo: No
Wait to Start Feature is Present: No
Ambient Temperature Sensor Location: DCM
Steering Ratio at Zero (0-25.4): 0.000
Steering Ratio at Positive Angle 1 (0-25.4): 0.000
Steering Ratio at Positive Angle 2 (0-25.4): 0.000
Steering Ratio at Positive Angle 3 (0-25.4): 0.000
Steering Ratio at Positive Angle 4 (0-25.4): 0.000
Steering Ratio at Positive Angle 5 (0-25.4): 0.000
Rear Door Lock Switch Present: No
Speed Limiter Present: No
Seat Belt Reminder Module Present: No
Child Display Present: No
Off-Road Pages Present: No
Ambient Lighting Present: No
Semi Automatic Parking System Present: No
Park With Stop Present: No
VehConfig 6:
___________________
Analog Door Sensor Configuration: None
Brake Type Configuration (M156/7): Signal Not available
Air Quality System Present: No
Steering Ratio at Negative Angle 1 (0-25.4): 0.000
Steering Ratio at Negative Angle 2 (0-25.4): 0.000
Steering Ratio at Negative Angle 3 (0-25.4): 0.000
Steering Ratio at Negative Angle 4 (0-25.4): 0.000
Steering Ratio at Negative Angle 5 (0-25.4): 0.000
Dynamic Tire Circumference, Front Only (0-65534 mm): 65535.000 mm
ECUConfig 3:
___________________
Configuration Messages Status 3: Programmed
Rear Camera Present: Yes
DRL Customer Setting Option Present: No
Power Inverter Present: No
Front Park Assist Present: No
Front Heated Seats Present: Yes
Front Ventilated Seats Present: Yes
Country of Destination: MARKET 2 // United States of America
Cabin Equalization Curve: Crew Cab Premium (Alpine 12-ch) (DS)
CTP Passive Entry Present: No
SDAR Travel Link Feature Present: Yes
DAB/DMB Present: No
Vehicle Theft Alarm (VTA) System Present: Yes
Heated Steering Wheel Present: Yes
Overdrive Switch Feature Present: No
Surround Sound Feature Present: Yes
Power Door Locks Present: Yes
Antenna Type: Passive Primary and no secondary antenna
Hybrid Electric Powertrain Present: No
Disable CD Eject: No
Tow Haul Switch Feature Present: No
Hill Descent Switch Feature Present: No
PASS Call Feature Present: No
PASS Hands-Free Phone Feature Present: No
External Port Type: Absent
PASS WiFi Antenna Present: No
ECUConfig 4:
___________________
ERS Available: No
Rear Wheel Dually: No
Max Gear: Not Set
Virtual Speedometer Units: Not Set
Speedometer Range Max Scale: Not Set
IPC Configuration Feature Present: No
PTO Present: No
Ambient Dimmer: No
Heated Seat Present: Yes
Split Shaft Present: No
Manual Headlamp Leveling: No
Gear Shift Indicator: No
CBC Features:
___________________
Tip Start Enabled: No
Dual Start Relay System Present: No
Wiper Service Position Enabled: No
Fuel Door Release Enabled: No
Trailer Tow Present: Yes
Quad Headlamps Enable: Yes
Horn Chirp Allowed: Yes
Bi Xenon Headlamps Enabled: Yes
Hazard Lamp Configuration: Latching
Park Lamp Loadshed Enabled: Yes
Front Fog Lamp Dropout Enabled: Yes
Combined Rear Lighting Enabled: Yes
Side Repeaters Enabled: No
One Touch Lane Changed: Yes
Exterior Light Loadshed Enabled: Yes
Front Wiper Park Enabled: Yes
Rear Wiper Park Enabled: No
Reversible Washer Pump Enabled: No
Single Element Tail Lamp: No
DRL Configuration: Optional DRL
DRL Lamp Location: None
DRL Dropout Enabled: Yes
Tunnel Detection: No
Military Vehicle Present: No
LED Reverse Lamps Present: No
LED Stop Lamps Present: Yes
LED Rear Turn Lamps Present: Yes
LED Tail Lamps Present: Yes
LED Rear Fog Lamps Present: No
LED License Lamps Present: No
LED Front Turn Lamps Present: Yes
LED Front Fog Lamps Present: No
LED Dedicated DRL Present: No
LED Low Beam Lamps Present: No
LED High Beam Lamps Present: No
LED Front Park/Marker Lamps Present: Yes
Avh5153
Washington PA
Illuminated approach Enabled: No
Door Lock Switch Signal Front Left Usage: Driver Door Analog Ajar Switch
Door Lock Switch Signal Front Right Usage: Passenger Door Analog Ajar Switch
TCSM Present: No
Headlamp Wash Spray Duration (at 100 ms intervals): 1200ms
Headlamp Wash Interval: wash cycle #11
Headlamp Wash Shot: Single
Front Wiper Wipes After Wash: 2 Wipes
Headlamp Washer Low Fluid Shut-Off Enable: Yes
Side Mirror Repeaters used as side markers: No
Intermittent Wiper States: 5 Intermittent Wiper position Switch
LED CHMSL Lamp Present: No
CBC Config I/O:
___________________
Ambient Light Dimmer Wheel Input Present: No
Low Beam Output Present: Yes
Backup-Reverse Switch Input Present: No
Front Driver Analog Door Ajar Input Present - Pin F9: Yes
Connector F Pin 23: Door Lock Switch Signal Front Passenger Present: Yes
ERS Switch/Inverter On/Off Switch Input Present: No
Connector F Pin 29: Flipper Glass Ajar Input Present: No
Connector E Pin 15: Fuel Level Sensor #2 Input Present: No
Connector A Pin 11: Hood Ajar Switch Input Present: No
Connector E Pin 14: Hard Top Sense/Stealth Input Present: No
Connector F Pin 21: Inverter Status Input Present: Yes
Connector F Pin 22: Manual T-Case/Analog Spare Input #1 Present: No
Connector F Pin 26: Trunk/Liftgate Ajar Signal Input Present: No
Connector G Pin 18: Left Rear Door Ajar Signal/RLS Analog In 3 Input Present: Yes
Trunk/Flipper Glass Relay Switch Signal Input Present: No
Rear Wiper Motor Park Switch Input Present: No
Connector A Pin 8: Washer Fluid Level Sense Signal Input Present: Yes
Connector E Pin 5: Sunshade Switch Input Present: Yes
Connector E Pin 31: ESM Present - Power Ignition Run: Yes
Connector G Pin 16/Connector E Pin 13: ESP Switch Input Present: Yes
Connector E Pin 35: Adjustable Pedal Motor Relay Output Present: No
Connector F Pin 6: Baggage Compartment Lamps Output Present: Yes
Connector D Pin 7: Diesel Cabin Heater #1 Output Present: No
Connector D Pin 9: Diesel Cabin Heater #2 Output Present: No
Connector D Pin 10: Diesel Cabin Heater #3 Output Present: No
Connector D Pin 11: ESCL Unlock Control Output Present: No
Connector D Pin 12: Diesel Fuel Heater Relay Output Present: No
Right Dedicated DRL Lamp/Right Signature LED Present/Right Front Turn Signal #2/Headlamp Leveling Output Present: No
Left Dedicated DRL Lamps/ Left Front Turn Signal #2/Left Signature LED Present : No
Connector E Pin 34: Flipper Glass #2 Output Present: No
Connector F Pin 7/Connector G Pin 24: Foot Well Lamps Output Present: Yes
Connector A Pin 01 and Connector D Pin 13: Front Fog Lamps Output Present: Yes
Connector D Pin 6: Headlamp Washer Motor Control Output Present: No
110/220 VAC Inverter Power Switch Input Present - Pin F35: Yes
Connector F Pin 38: Snow Plow Low Beam Relay Control LT0/Relay LSD Spare #1 Output Present: No
Connector E Pin 20: HID LSD Output Present/Relay LSD Spare #2 Output Present: No
Connector D Pin 24: Snow Plow LSD #3/Relay LSD Spare #3 Output Present: No
IOD ON LSD Output Present: No
Connector E Pin 10: Head Rest (IOD OFF LSD Output Present): No
Connector G Pin 23: Passenger Airbag Off LED Output Present: No
Connector E Pin 39/Connector F Pin 5: Rear Fog Lamps Output Present: Yes
Connector E Pin 4/Connector F Pin 32: Rear Park Lamps Output Present: Yes
Connector E Pin 3/Connector F Pin 42: Rear Turn Lamps Output Present: No
Auxliary Fuel Pump(Rear Wiper MTR Ctrl/Flipper Glass #1 Output Present): No
Connector E Pin 9: Run-ACC Y Relay #2 Output Present: Yes
Connector A Pin 10 /Connector D Pin 5 : Side Repeaters/Front Side Markers Output Present: No
Connector E pin 8: Sunshade Control Output Present: No
Connector E Pin 42: Ram Box/Tail Gate Lock (Thatum Lock Output) Present: Yes
Connector E Pin 41: Ram Box/Tail Gate Unlock (Thatchum Unlock) Output Present: Yes
Connector E Pin 23: Trailer Backup Lamps Output Present: Yes
Connector E Pin 24: Trailer Tail Lamp Relay Control Output Present: Yes
Connector F Pin 36: Trailer Turn Stop Relay Control Left Output Present: Yes
Connector E Pin 22: Trailer Turn Stop Relay Control Right Output Present: Yes
Connector F Pin 4: Trunk/Flipper Glass Relay Output Present: No
Connector G Pin 15: UGDO Feed Output Present: Yes
Connector G Pin 2: Vehicle Theft Alarm (VTA) Warning LED Output Present: Yes
Connector A Pin 14: Washer Motor Control Right Rear Output Present/Front Camera Washer: No
Connector E Pin 11: Park Brake Input Present: Yes
Connector A Pin 24: Ignition UNLOCK RUN START Present: Yes
Connector E Pin 37: IOD Relay Off HSD (High Side) Present: No
Connector E Pin 7: IOD Relay On High Side Present: No
Connector D Pin 22/ Connector D Pin 23: Ambient Temperature Sensor Present: No
CBC Config I/O Usage:
___________________
ESCL Usage: ESCL
Connector F Pin 22: ANALOG SPARE INPUT #1 Usage: Sunshade Switch
Connector G Pin 8: Trunk/Flipper Glass/Liftgate Release Outside Handle Switch/Upfitter Combined Function: Inside mounted Switch
Connector F Pin 41: Backup-Reverse lamp Left: Yes
Connector E Pin 1: Backup-Reverse lamp Right: Yes
Connector F Pin 5: Fog Lamp Rear Left/High Beam Shutter: Left High Beam Shutter
Connector E Pin 39: Fog Lamp Rear Right/High Beam Shutter: Right High Beam Shutter
Connector F Pin 42: Right Rear Turn Signal: Right Rear Turn Signal
Connector E Pin 3: Left Rear Turn Signal: Left Rear Turn Signal
Connector E Pin 8: Sunshade Control Usage: Sunshade control
Connector D Pin 1: Left High Beam Feed: Left High Beam
Connector A Pin 2: Right High Beam Feed/Right Park Lamp Usage: Right High Beam
Front Driver Door Ajar Switch Signal Usage (Lamp Diagnostics): Left Front Lamp Diagnostics - Jeep/Truck
Front Passenger Door Ajar Switch Signal Usage: Right Front Lamp Diagnostics - Jeep/Truck
Door Ajar Switch Signal Rear Left Usage (Lamp Diagnostics): Left Rear Lamp Diagnostics - Jeep/Truck
Connector F Pin 6: Baggage Compartment Lamps Usage: Truck Cargo Lamps
Connector F Pin 4: Trunk/Flipper Glass Relay Release Usage (IP Decklid Switch SIG on L's): Trunk/Liftgate Release
Connector F Pin 31: Right Rear Lamp Diagnostics/Right Rear Door Ajar Switch Signal Usage: Right Rear Lamp Diagnostics - Jeep/Truck
Connector D Pin 21: Brake Fluid Level Switch: 10K Parallel Resistor
Connector D Pin 12: Diesel Fuel Heater Relay Usage: Connect Output to Run Start Ignition Relay API (Truck Usage)
Connector F Pin 29: Flipper Glass Ajar Signal (Horn Switch input on LA): Horn Switch Input
Relay LSD Spare #1 Usage: Not defined
Relay LSD Spare #2 Usage: Not defined
Spare LSD Relay #3 Usage: Cabin Heater #4
Connector A Pin 11: Hood Ajar Switch Signal Usage: 1K parallel resistor
Connector E Pin 30: ESP Switch/HSD Usage: Cargo Lamp Switch
Connector E Pin 21: Ignition Off Draw (IOD) Relay On LSD Usage: M156 Fuel Door Inhibit
Connector E Pin 10: Ignition Off Draw Relay Off LSD Usage: (WK) Head Rest
Connector E Pin 7: Ignition Off Draw Relay On HSD Usage: Snow Plow Left Turn
Connector E Pin 37: Ignition Off Draw Relay Off HSD Usage: Snow Plow Right Turn Lamp
Left Dedicated DRL/High Beam Usage: Left DRL
Right DRL/High Beam Usage: Right DRL
Connector E Pin 31: ESM Usage/TOPPER CHMSL: Topper CHMSL
Connector E Pin 29: Back-Up Reverse Switch Usage: Reverse Switch
Connector E Pin 42: Thatcham Lock Usage: Ram Box/Tailgate (-)
Ram Box/THATCHAM UNLOCK Usage: Ram Box/Tailgate (+)
Hardtop Stealth Usage: Driver Inside Door Handle Switch/Glove Box Switch ZD
Rear Left Door Ajar Usage: Analog Door Ajar Switch Rear Left
Rear Right Door Ajar Usage: Analog Door Ajar Switch Rear Right
Stop&Start Enable Switch Present: No
2014 CBC Config I/O & Feat.:
___________________
Avh5153
Washington PA
Connector F Pin 13: Left Sliding Door Switch Input (B-Pillar)/Analog Spare Input #2: Disabled
Connector F Pin 14: Right Sliding Door Switch Input (B-Pillar)/Analog Spare Input #3: Disabled
Connector F Pin 15: Driver Door Lock Switch/Analog Spare Input #4: Disabled
Connector F Pin 16: Passenger Door Lock Switch/Analog Spare Input #5: Disabled
Analog Spare Input #6: Disabled
Baggage (Cargo) Lamp Output Disabled with vehicle moving: No
CHMSL Lamp Output Disabled: No
Diesel Fuel Heater Enabled: No
Manual Door Locks Present: No
Connector E Pin 48 (Tied internally to Connector A Pin16): Rear Wiper Motor Control Output Present: Rear Wiper
ERS Input Usage: ERS
Rain Sensor Module #2 Present: No
Humidity Sensor Long Present: No
Auto High Beam Module Location: None
Pitch and Roll Present: No
License Plate Lamp Disabled: No
CBC Extern.Light Calibr.:
___________________
Auto Headlamp On Threshold (0-5 V): 3.314 V
Auto Headlamp Off Threshold (0-5 V): 2.549 V
Left Side DRL Voltage Target: 6.0 V
Right Side DRL Voltage Target: 6.0 V
Left Low Beam Voltage Regulation: 13 V
Left High Beam Voltage Regulation: 13 V
Right Low Beam Voltage Regulation: 13 V
Right High Beam Voltage Regulation: 13 V
Left Front Corner Voltage: 13 V
Right Front Corner Voltage: 13 V
Left Rear Corner Voltage: 13 V
Right Rear Corner Voltage: 13 V
Alarm - ITM:
___________________
Siren present: No
Ultrasonics present: No
Tilt Sensor present: No
Brakes:
___________________
Brake System ECU Configuration A: Value 18
Wheel 18 Inch Overall ESC Maserati: Yes
Battery:
___________________
IBS Activate MWU: No
Battery Type: Battery ID 4
IBS Quiescence Current Limit (-250-0 mA): -250.000 mA
IBS Minimum Voltage Limit (0-25.4 V): 5.000 V
IBS Minimal Charge Limit (0-125 Ah): 10.000 Ah
IBS Standby Time (0-7620): 7620.000 sec
IBS Minimum Charge Limit (0-2500mA): 600.000 mA
Cluster:
___________________
Fuel Tank 1 Calibration, E Stop Datum for Fuel Voltage 1: 0
Fuel Tank 1 Calibration, Empty: 2%
Fuel Tank 1 Calibration, LFW: 8%
Cluster:
___________________
Fuel Tank 2 Calibration, Full datum for Fuel Voltage 2: 0
Fuel Tank 2 Calibration, E Stop datum for Fuel Voltage 2: 0
Fuel Tank 2 Calibration, Empty: 2%
Fuel Tank 2 Calibration, LFW: 8%
Doors:
___________________
Global Windows Up: No
Global Windows Down: No
Sun Shade Present: No
Power Folding Mirrors Present: No
Heated Mirrors Present: Yes
Mirror Turn Signals Present: Yes
Driver Memory Mirrors Present: Yes
Passenger Memory Mirror Present: Yes
Electro-Chromatic Driver Mirror Present: No
Electro-Chromatic Passenger Mirror Present: No
Tow Mirror Present: Yes
Blindspot Mirror Present: No
Mirror Approach Lights Present: Yes
Door Map Pocket LED Present (Ambient Lights): Yes
Door Courtesy Lamps Present: No
Window Motor Type: No
Window Hall Sensors Present: No
Door Handle LED Present (Ambient Lights): Yes
Frameless Window Present: No
LIN and Misc:
___________________
Fobik Safe Alert No Reply: No
Fobik Safe Alert on System Fault: No
Fobik Safe Alert on Search Timeout: No
Snow Plow Enabled: No
Panic Enabled: Yes
Compass Mounting Orientation: Upside Down
Washer Fluid Level Voltage Threshold: 4.06 V
Fobik Safe Alert Per Ignition Cycle Counter: 2
IBS Present: Yes
ASBMM Present: No
RCM Present: No
Humidity Rain Light Sensor Present: No
Manual Trans Present: Yes
Smart Beam Present (AHBM): No
DC to DC Converter Present: No
ASBM Present: Yes
Auto Relock Time (1-255 sec): 60.000 sec
Vehicle Theft Alarm (VTA) System State: VTA
Electronic Overhead Module (EOM) Present: Yes
DC to DC Converter #2 Present: No
Illuminated Approach Interior Lighting Target Percent: 150 (75%)
Illuminated Approach Headlamp Target Percentage: 165 (82.50%)
Illuminated Approach Taillamp Target Percentage: 165 (82.50%)
Illuminated Approach Interior Lighting Ramp Up Time: 150 (3000 ms)
CRVMM Present: No
Clock Module Present: No
EVIC Switch Module Present: No
Terrain Switch Bank Module (TSBM) Module Present: No
Compass Mounting Angle (0-360 Deg.): 0.000 Deg.
Memory:
___________________
Memory Adjustable Pedals Present: No
Tilt/Telescope Steering Present: No
Memory Seat Present: Yes
Rear Heated Seats Present: No
Front Vented Seats Present: Yes
Heated Seat Material Type: Perforated Leather
Heated Wheel Material Type: Full Leather
Powertrain:
___________________
Vehicle is Equipped with Dosing Control Unit: Yes
Vehicle is equipped with Variable Geomeric Turbo Actuator: Yes
ECO Mode Configuration: Not Available
Dual Alternator Present: No
Safety:
___________________
ODS Present: No
Side Airbags present: No
Integrated EPP Present: No
BUX Market: No
Wireless:
___________________
AP5 Trunk Unlock: Not Present
Airport Scenario Trunk set: No
AP1 Left Front: Not Present
AP2 Right Front: Not Present
AP3 Left Rear: Not Present
AP4 Right Front: Not Set
Cust.Prog.Features:
___________________
Sound Horn on Lock: Enabled
Sound Horn on Remote Start: Enabled
Flash Lamps on Lock: Enabled
Headlamps ON with Wipers: Enabled
Auto Wipers: Not enabled
Auto Lock: Enabled
Auto Unlock: Enabled
Delay Lock: Not enabled
Illuminated Approach Time (0-254 sec): 30.000 sec
Headlamp Delay Time (0-254 sec): 0.000 sec
Accessory Delay Time (0-65534 sec): 45.000 sec
Daytime Running Lamps: Enabled
Auto High Beam: Not enabled
Door Alert Enable: Not enabled
One Press All Unlock Enable: Enabled
Auto Relock: Enabled
EC Mirror Auto-Dimming Enabled: Enabled
Remote Lowering Horn Enabled: Not enabled
Remote Lowering Lights Enabled: Not enabled
Ambient Dimmer Level (0-100%): 100.000 %
Cabin Net:
___________________
RBSM Right Blind Spot Module: Not enabled
BSS Blind-Spot Sensor/LBSS Left Blind-Spot Sensor: Not enabled
BCM Body Interior Bus: Enabled
HSM Heated Seat Module: Enabled
DDM Driver Door Module: Enabled
PDM Passenger Door Module: Enabled
DMRL Door Module Rear Left: Not enabled
DMRR Door Module Rear Right: Not enabled
HVAC Heat Ventillation Air Conditioner: Enabled
MSM Memory Seat Module: Enabled
PLGM Power Liftgate Module: Not enabled
PSDML Power Sliding Door Left: Not enabled
PSDMR Power Sliding Door Right: Not enabled
FSM Fold Stow Module: Not enabled
PTCM Power Top Control: Not enabled
RBC Regenerative Brakes Control: Not enabled
Radio/TGW Telematic Gateway: Enabled
Clock: Not enabled
VSIM Vehicle System Interface: Not enabled
ITM Intrusion Module: Not enabled
AMP Amplifier: Enabled
EDM External Disc Module: Enabled
HFM/CTM Hands-Free Module: Not enabled
ICS Integrated Center Stack: Enabled
VES2 Vehicle Entertainment 2nd Row: Not enabled
VES3 Vehicle Entertainment Last Row: Not enabled
CRSM Comfort Rear Seats Module: Not enabled
HVAC_R Rear Heat Ventillation Air Conditioner: Not enabled
P/T Chassis Net:
___________________
ACC Adaptive Cruise Control: Not enabled
ADCM Active Dumping Control: Not enabled
AHLM/AFLS Headlamp Leveling: Not enabled
ASCM Air Suspension Control Module: Not enabled
BCM (PT) Body Control Module: Enabled
DTCM Drive Train Control: Enabled
ECM/PCM Powertrain Control: Enabled
EPS Electric Power Steering: Not enabled
ESM Electronic Shift Module: Not enabled
ABS/ESC: Enabled
EPB Electronic Parking Brake: Not enabled
RFH Radio Frequency Hub: Enabled
IPC Instrument Panel: Enabled
ACC/DASM Adaptive Cruise Control/Driver Assistance Module: Not enabled
FDCM Final Drive Control: Not enabled
EPPM Electronic Pedestrian Protection: Not enabled
ORC Occupant Restraint control: Enabled
PTS Parktronics: Not enabled
RBT Driver: Not enabled
RBT Passenger: Not enabled
SCCM Steering Column Control: Enabled
ELSD Electronic Limited Slip Differential: Not enabled
TCM Transmission Control: Not enabled
TPM Tire Pressure Control: Enabled
PASS (PT) Personal Assistance and Safety Services: Not enabled
AFLS Discharge lamps: Not enabled
ITBM/HWM Integrated Trailer Brake Module: Enabled
OCM Occupant Classification Module: Not enabled
FFCM/HALF Front Facing Camera Module: Not enabled
ANC Active Noise Cancellation: Not enabled
Audio/Telemat Net:
___________________
AMP Amplifier: Not enabled
ICS Integrated Center Stack: Not enabled
PASS (A/T) Personal Assistance and Safety Services: Not enabled
SDARV Satellite Video Receiver: Not enabled
DVD Changer: Not enabled
HFM Hands Free Module: Not enabled
Hybrid LAN Net:
___________________
APM Accessory Power Module: Not enabled
BPCM Battery Pack Control: Not enabled
HCP Hybrid Control Processor: Not enabled
MCPA Motor Control Processor A: Not enabled
MCPB/ESC Motor Control Processor B: Not enabled
Avh5153
Washington PA
Sorry for posting here in multiple posts but couldn't get the file to upload. I did a search and couldn't find much related to units, but what you're saying makes a lot of sense. Let me know what else you think I could take a look at.
Roman217
Metro Detroit, MI
Interesting, the 2013 BCM doesn't have a section for the "customer settings menu" options. Do you have the windows or Android version of AlfaOBD?
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
The 2013 7" EVIC also won't display any customer settings menus either.
Avh5153
Washington PA
Android version
