61N150W
Anchorage, AK
Finally did the conversion today. I had been using my UAS with the infotainment bezel.
Install was in a 2014 Bighorn 1500 (Canadian) using HVAC Module 68268186AA. I have full heat and movement of the blend doors.
I did however use a dual zone bezel simply because I had been on the search for a single zone with no luck and gave up. At initial boot-up, it was trying to offer me both zones but wouldn't allow me to increase the temperature (would auto drop to max cold). I shut it off and the screen stayed lit but blank for about 10 mins, even after I left the truck. Once it shut off completely, I started it back up and the controls were now single zone and temp operated as intended. [emoji106]
I do now have a CEL, but haven't looked into it. May have been from pulling the negative battery cable.
likes2build
Mohawk Valley, NY
2018 Express RCSB
3.6 Pentastar
I had a CEL after the swap but cleared it with a scanner. Others that have had the CEL after the swap stated that it goes away after some key cycles.
I think the only way to get a single zone ATC bezel is to purchase one modified from M2Mods as FCA really might not make one.
Jaywoo
Ward, AR
2021 & 2018
Hemi 5.7 & Cummins
Infotainment sells a single zone bezel.
likes2build
Mohawk Valley, NY
2018 Express RCSB
3.6 Pentastar
If it's the one in the picture, that is a basic stock single zone Mopar #1UJ96DX9AF and it's a Manual Control, I have one of those. The single zone custom made is from M2Mods is an ATC with the word AUTO on the fan controller (set it and forget it, lol) if I remember correctly. Anybody?
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
interesting that your 2014 ram 1500 temperature slider controls and blend doors work correctly on your 18 UAS radio using the 13-17 68268186AA module.
If only there was some consistency in which module to use with these radios. Every time it seems things are figured it there's a new curve ball thrown.
Edit: reshared/posted in...
HVAC problem with UAS upgrade in '18 truck.
M² Mods.
SitKneelBend
St. Louis
3.6 Pentastar
M² Mods.
With enough curve balls thrown, you can learn how to hit them! I think you have several threads on here with you knocking curve balls around, scoring runs...
Mpgrimm2
Preferred Vendor
SC
5.7L
Here's what it looks like right now trying to nail down this UAx to HVAC module issue...
M² Mods.
Jaywoo
Ward, AR
2021 & 2018
Hemi 5.7 & Cummins
True, no auto button on the bezel, but there is an auto button on the climate control of the radio that does the same thing. The part number is 1UJ96DX9AK though.
likes2build
Mohawk Valley, NY
2018 Express RCSB
3.6 Pentastar
Same part # different suffix, last 2 letters change all the time depending on a superseded #
And this would be the super nice custom M2Mods Mpgrimm2 single zone ATC bezel that FCA doesn't make.
Mpgrimm2
Preferred Vendor
SC
5.7L
Just to clear up confusion. With a working Single Zone ATC mod (Auto Temp Control) you've got 2 official bezel options...
1) Single Zone MTC (left) with the menu based "Auto" feature - PN: 1uj96xxxx
(2) Dual Zone ATC (right) with both menu and hardware "Auto" button (but unusable pass. side temp buttons) - PN: 1uj97xxxx
and the unofficial 3rd bezel option of modifying/combining dual zone control board with single zone bezel = Single Zone ATC - PN: by M² Mods
(about 6-8 of these out in the wild now)
MTLKEBEK
Montréal
Does anyone have an extra USB hub? 68328704AC Or 5XG28DX9AC.
Thanks!
likes2build
Mohawk Valley, NY
2018 Express RCSB
3.6 Pentastar
Thanks!
Absolutely, Benny @AllMoparParts.com and the best prices too!
Edit: Sorry all of what I wrote wasn't there when I hit post.
AllMoparParts is a vendor here on the Forum. Just go to the vendor area and you will easily find them. Just post up what you are looking for and Benny will respond. They have the absolute best prices on new OEM Mopar parts I've found along with wonderful service and a factory warranty.
Administrator
I got a bounce back, is that his email?
Not his email, AllMoparParts.com is Benny's username here on the forum. Look for it the vender section and post your request up there.
If you put @ in front of anyone's username on this forum, it is "mentioning" them and they will get a notification.
Big Terry
Dover OH
So after doing a casual skim of this thread I have no seen mention of something that would seem relevant- In doing an update from a 3 or 5 inch to an 8.4 with nav, no one seems to have mentioned replacing the antenna on the roof with the shark fin. I am guessing, but I assumed that the shark fin was not just the 4g antenna but also the GPS antenna for the nav equipped radios.
I dont need, but my roommate with a 17 Tradesman 2500 wants to do the swap and he's been drooling over the cheap-ass "tesla-like" radios on ebay. I have been doing my damnedest to convince him how poor of a choice that is because he is simply looking at it from the out-of-pocket cost perspective up front, and not at the possibility that cheap ass chinese head unit will take a **** on him in 6 months. I want to help him do the right thing lol, and trying to price everything. And thus far it doesn't seem as though anyone has mentioned having to add or swap out for a shark fin.
