fearroyo
You certain that's from a 2018? Is it a Canadian unit or non-nav?
In early testing, i tried a late model 2017 (MY_17.5) Compass USA UAQ PN: 68283240Ax (Application Version 18.7) in my 2013 ram before we figured out the correct USB Hub/wiring as well as blend door temp issues (fixed with 18 HVAC module or ATC wiring/sensors)...
and ran into some issues (stuck on KM/h vs MP/h, didn't recognize key in run position)... but my 13 ram never worked correctly with ANY 2016 ram radios either (tried 3); all other 13-18 ram radios worked fine.
@DeereGuy had better luck with it in his 2016 truck but there were still some issues that may have been helped with a newer SW/Application version (v18.7) that we never found from a compass VIN.
Testing never went further with that radio and it ended up as a parts donor to fix a ram UAQ with a broken screen/mount.
M² Mods.
The VIN does come back to a US 2018 Jeep Compass. I have a 2017 RAM 1500 with the 8.4 and the 7-speed ATC.
