- Joined
- Sep 17, 2018
- Posts
- 193
- Reaction score
- 147
- Location
- Hackettstown, NJ
- Ram Year
- 2022
- Engine
- hemi 6.4
I installed Mike's ATC harness to go with my UAQ radio. My wife bought the radio from infotainment and it came with a dual zone pannel, the USB hub, a harness and control box. I did not like the dual zone control since my system had none of the options so I got a single zone off ebay. The issue it never really controlled by temperature right and with 3 clicks it show hot but the temp control hardly moved. Reading this forum I saw putting it to single ATC would fix the issue, and it did but then I wanted the ATC function. I spoke to Mike and he gave me a few options and I went with the complete kit. The only thing I did not have is the holder for the humidity sensor since my truck is a express and has none of those features. I looked on ebay and found a guy selling the whole thing, windshield clip, cover and sensor. He was not sure if the sensor worked but I did not care since I ordered a new one from Mike. I used 3/8 3M tape to hold the clip to the window and ran the wire under the headliner. Removed the main harness from infotainment and and ran Mike new main harness. Installed the temp sensor in the panel under the steering wheel. Hooked the battery back up and tested. It took 2 power cycles for everything to sync but once it did I now have a functioning ATC in my 2018 Express.
Thanks Mike!!
Thanks Mike!!
