adrianp89
- Joined
- Sep 3, 2015
- Posts
- 3,179
- Reaction score
- 1,277
- Location
- Tampa Bay, FL
- Ram Year
- 2019
- Engine
- Hemi 5.7
I am almost positive Jensen will not work with Maestro features.
I picked the maestro rr, ch3 harness and Kenwood deck for just over 400I see their compatable radio's now. It looks like my 250$ touchscreen with navi isn't compatable, and the only radio's that are are up around 6-700$...
Now do I need this or not.... Hm...
Does the arm rest USB work with the car play using the acc USB?
you will have to replace the center usb with the uram usb unit from iDatalink to use your apple car play.
its all one piece with the circuit board, usb and micro audio jack.Not the USB itself just the adapter with the circuit card that connects to the harness right?
I know this is an old thread, but I have been researching the URam accessory to integrate the USB port. It will not allow you to use CarPlay or the android version through it for some reason. The crutchfield website confirms it.
Correct, it will only allow you to retain the USB port, but car play will not work. I ran the usb extension cable that came with the unit down through the center stack behind the trim and under the glovebox/passenger foot area-out of sight out of mind and my lighting cable is always plugged in so not much worry there.
I have the idatalink uram in place of the original usb hub, and CarPlay works just fine.I know this is an old thread, but I have been researching the URam accessory to integrate the USB port. It will not allow you to use CarPlay or the android version through it for some reason. The crutchfield website confirms it.
I can confirm it works for the pioneer avh-4200 nex (everyday for a year) and now my alpine iLX-107. The alpine is wireless CarPlay, but the uram is plugged into the usb input on the alpine for when I need to plug it in.
