Idle RPM?
Micks-hemi
Abbotsford,BC
Hey Gang:
I have a 2018 rcsb 4X4,hemi and 6Speed with 3.52 diff gearing. My problem is when stuck in rush hour traffic,my truck just wants to go even at idle. I have to keep my foot on the brakes at all times. I've even tried to leave a BIG gap between me and the vehicle in front of me. As soon as I let off the brakes,away she goes again.
My question is,what is idle RPM supposed to be? In gear i'm at around 800. Is that a bit high? Can it be lowered?
Thanks,Mickey
tidefan1967
Summerville, South Carolina
Are you sure about the 6spd auto? I was under the impression that all 1500 model trucks in 2018 had 8spd automatics and either 3.21 or 3.92 gears. My RAM (2017 with 5.7 hemi/8spd/3.92s) idles at around 500 in gear so I would think yours should be about the same. Maybe disconnect the battery for a minute and give it a chance to relearn and there's always the dealer if you're still under warranty.
TheEnder
4.7L V8
Hey Gang:
Thanks,Mickey
My 2013 with the 4.7 idles (in drive) at 500-600 RPMs with the 6 Speed 65RFE. It only idles at 800 RPM early in the morning when the engine is cold.
Sent from my iPhone XS Max using Tapatalk
JoeCo
NY
I saw somewhere on here a Canadian member mentioned that their country seems to be a dumping ground for old FCA transmissions and apparently a lot of the rams up there still have the 6 speeds in them.
turkeybird56
Central Texas
800 sounds a lil high, but not an inane amount high. MY 19 idles 600-800, but unless I put my Blue Drive reader on it, not gonna know actual number. The idle number factor would be heat vs cold and whether or not AC on.....
Lyle Longboat
2011 Ram 1500 5.7 Sport CC
Moosonee, ON, CANADA
I have the 5 speed lol and I’m in Ontario, but truck was made in Warren Mich!
JoeCo
NY
On a 2011 though, right? My 2011 had a 5 speed as well, but here in the states finding a 6 speed after 2013 is fairly rare, especially in more recent years from what I have seen. Seemed like a good 90-95% were 8 speed the last time I was looking/shopping for my 2017.
Octane
U S.A.
Clean the throttle body especially where the butterfly forms a dirty ring around it on the inner sidewall of the throttlebody.I use a toothbrush with cleaner on it and wipe it out with a rag
Us Canucks are lucky,we're FCA's dumping ground for the older RFE trannies,lol. I'm guessing he's got a lower trim level truck,as it's only the Expresses and lower that get the 6 speed,Sports and higher trim level trucks get the 8 speed
Propanedr
Homestead & Sebring Florida
did the OP ever figure out what the idle problem was. Im experiencing something similar. Ive even removed the intake manifold and changed the o rings. Used several cans of brake clean and carb clean to try and pinpoint the vacuum leak (if there is one). still unsuccessful. One day while in park i slowly raised the RPM up to about 2k. Lifted off the accelerator and the rpms kept creeping up all the way to 4k before i shut it down. sorry to hijack your thread, but i hope you found a solution.
