Inertia 400 CI Stroker pics!
matt99
Shreveport, LA
I was thinking, the venom hood probably has a few more inches of clearance than the SRT...just an option if you still have the clearance issue
sawcut64
sawcut64
Arlington/DFW Texas
I'm probably going to ditch the whole 09' truck intake, I took apart the solenoid and it has a circuit board inside.....I just don't think I can make it work properly. So I'll just stick with the ported 6.1 instead.
matt99
Shreveport, LA
they are going to eventually make trucks that are impossible to mod engine wise.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Damn Sam coming along, I shot ya a pic mess of the 2 motors we pulled awhile ago. Shame these trucks arnt quick pulls, 2 cars in 3 hours.
sawcut64
sawcut64
Arlington/DFW Texas
I had this motor pulled in 4.5 hours, twice as much time putting it all back. Having a HUGE Superchips issue, seems to be locked up giving me a G35 code. Not sure WTF is the problem...... It won't let me reset the PCM either but the motor runs....well sort of, with 6.1 injectors, a big cam, and canned Superchips tune it's running like ass. Need to get the Diablo custom tune loaded.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Im jealous of yall 2 wheel guys on yanking the motor. Hope your Pcm is not gonna lock up and you can get the Stu tune in there.
sawcut64
sawcut64
Arlington/DFW Texas
Going to swap the injectors back to 5.7 injectors tomorrow in hopes it will run halfway decent. Really bumming me out this friggin' Superchips/PCM issue....
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
I hear ya... theres always a catch on these trucks once you think everything is gonna work...
sawcut64
sawcut64
Arlington/DFW Texas
It's not that I have a problem so much as I don't exactly know what the problem is. I see the symptoms, ruled out a few things, but with a project this big it's hard to retrace your steps....assuming it was that and not just a coincidence? Another thought is it may be some weird issue with the 6.1 injectors and my PCM. It's not the battery, fuses are fine, grounds are all attached, clean, and tight....WTF?!?!?!
truckin151
2013 sport
So what numbers do you expect that thing to put down once you are done with it?
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Are you gonna swing to the dark side and spray it for a 10?
sawcut64
sawcut64
Arlington/DFW Texas
If I can get deep enough in the 11's then I'll probably toss a 125 shot at it to go 10's....then spend the next couple weeks fixing **** I busted because of it!!!
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Ahhhh come on, you prob already have a beefed up trans and drive shaft so thats 2 of the main things that will say :flipthebird: on a 10 sec pass in our bricks.
sawcut64
sawcut64
Arlington/DFW Texas
if u need help or just an extra set of hands id love to help out.
Appreciate the offer but I really have not much of a clue as to what root problem is. I'll contact Superchips tomorrow, yank my intake and swap the injectors and recheck the head grounds and all wiring.
sawcut64
sawcut64
Arlington/DFW Texas
Nope stock trans and driveshaft with 51K. Reinstalled the Edge converter when the motor was out, but aside from that 100% factory.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Wow thought those woulda been done when you just had the heads and 268 on the old setup. Well do you atleast have a drive shaft loop in place for all that power your gonna be sending down it?
sawcut64
sawcut64
Arlington/DFW Texas
Yes my driveshaft loop is in place......well that place is on my work bench! :D
sawcut64
sawcut64
Arlington/DFW Texas
Well still haven't figured it out, something electrical is causing this. I've ruled out the battery, wideband, e-fan, Superchips, tried another key, swapped out a slightly funky O2, checked grounds.....next up is to completely remove the alarm(want it out anyway). That doesn't correct it then I'll have to swap in the 5.7 injectors and maybe even toss in a 6.1 cam to get the truck drivable. Something is not allowing Superchips to begin to remove the program or allow me to reset the PCM by pulling the fuse. I hope it the alarm because I'm running out of options, everything went smooth in the install....starting to ******* **** me the **** off just a tad!!!! Anyway big thanks to Randtx(Randy), Sil, and Mark for all the help!!
