- Joined
- Jan 17, 2016
- Posts
- 23,824
- Reaction score
- 54,848
- Ram Year
- 14 Sport
- Engine
- 5.7
How Engine Oil Helps Piston Ring Seal
The next time you're building an engine, think about the “gasket” that you pour into it.
I’m hooked on that show also, it’s nice they feature lots of Mopar information.![]()
The next time you're building an engine, think about the “gasket” that you pour into it.www.motortrend.com
So, they saw the casting sand, but still gave it the go-ahead?
How was it even assembled like that?
What did they think would happen?
I'm a generator service and sales guy myself. Now involved in full turnkey designs and project management. I was at Cummins Eastern Canada many moons ago and know exactly what you're saying!
I then migrated to Detroit Diesel where they had the DDC/MTU line and had a large prime power aggregate demand supply project in Ontario where 4 x 2.75MW Series 4000 monsters were paralleled together to provide 4 x 2.5MW, so 10MW total prime power output, and the issues experienced were epic.
Interesting story on this project. So, we were in Unit #2 (all four units were side by each in their own enclosures) and commissioning the units one by one with 4-hour full load tests each unit. As this unit starts to wind up the vacuum inside the room is increasing at an unusual rate. The louvers (intake and discharge) got stuck closed as there was a communication issue to have them open on start up in the logic programming (as we diagnosed after the fact).
Didn't the enclosure start to suck itself in like a can sinking into deep ocean water with 6 of us in there, and I ******* you not when I say we smashed that E-Stop really quickly but the emergency shut down wasn't set properly at the factory and it continued to run.
Our lead tech had to do some wire crossing (thankfully the controller was open and all wiring exposed) really quickly and got the unit to shut down. All of us a a little tickle in the drawers on that one afterwards...lol
It was a real eye opener being in a can with a 20V4000 ramping up and imploding the enclosure from vacuum.Great story!
Did you know Benoit Parent @ CEC?
Incredible pressure! I was nervous, to say the least!Man, that's crazy. 2.5 million watts each?
You know those films where you see the people get too close to the jet engine intake?
The pressure must've been something else.
So, another generator story for y'all!
One of my techs was doing an annual service on a 16V92 Series engine (one of the best damn diesel engines ever made, but potential for danger is real with these ones...lol).
After he changes the oil and filters, does his checks, he fires it up to run it in preparation for the full load test, but he forgot to remove the piping for the turbo inlet (this is a must in preparation for IF something happens as anyone who knows these engines, knows you cover the turbo inlet to choke the engine of air to shut it down - it's the E-Stop, if you will).
Soooooo..... doesn't this engine go into mexican overdrive and take off (the Barber-Colman governors were known to be issues on these engines), with no way to stuff the engine to choke it, it starts singing, and these 2-stroke diesels can sing when oversped!
My tech RUNS out of the room (room configured in such a way that one has to go past the unit/engine to get to the generator room door to get in/out), and no sooner does he get to the door... BANG!!!!!!!! right out the side of the block came the engine guts... smashed into the cinderblock wall and took out an entire section of the wall, hot oil everywhere, smoke, and then a fire started....
Anyhooooo..... the fire was under control right away from the fire suppression system, but what a friggin mess, and that generator unit was done. Most importantly though is that my tech was okay! Although I believe his drawers were full, and for good reason!
The generator service industry is a dangerous one. You've got both mechanical and electrical dangers present, and one wrong move could cost a tech a lot.
