Issues after cam swap
Apager
Maine
Morning all,
Taking to this group for some help on my cam swap I did on my 09 HEMI. Just got done replacing JUST the cam (no lifters). Re timed it by lining up the marks on the chain with the phaser at 12 o clock and pointing the keyway of the crank at 3 o clock (or towards the 5.7 mark on the oil pump). After starting the truck runs extremely rough and idles high (1.2). Trying to rev it up and it doesn’t go past 2k rpm. Attached are the codes that it is throwing.
So my next question is where do I start. Take the valve covers off and see if the rockers are going down like they should? I’m really hoping it’s not the timing so I don’t have to tear everything apart again.
ANY help would be appreciated.
Apauger
Manhattan, KS USA
stock 5.7 with 6.4l cam and MDS delete
did you have the lifter cam issue the reason for replacing the cam?
the timing marks on the crank should be at the 6 o'clock position and then line the chain marks up with the crank and cam sprockets.
as for the codes it sugests it might be the VTT solenoid under the intake and right behind the cam sprocket
rockyj69
