Leveling 2013 Ram Outdoorsman
TheDuke
Noob here so bare with me.
Just purchased a 2013 Ram Outdoorsman 1500 4x4 5.7
Wanting to put a 2.5in level on the front. I've read about all the issues with the ball joints and UCA. Problem is, all the kits I've found require the air ride suspension, when I bought it, the owners manual wasn't included. Being a mechanical novice I'm not sure how to tell if it has the air ride. Also, if it doesn't have the air ride, what are my options outside of changing the entire suspension.
DannyMK2
Long Island, NY
2015 Power Wagon
plenty of ways to see if you have air ride. the easiest would be the ride height buttons on the center stack under the radio, or the entry/exit mode on the key fob. you can also take a look at your suspension. if you see coil springs, you dont have air ride.
with that said, if you dont have air ride, theres tons of leveling kits out there.
T
TheDuke
Ok, so I don't have the air ride.
Now that that's figured out, do you have any suggestions on kits I can use for a 2.5" level. Kits that include the uppercontrol arms and leveling kit.
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
Bilstein 5100's are a better option than spacers for leveling. You can read more information about that in the Guide to Leveling linked in my signature or search around the forum a bit.
With Bilsteins you don't necessarily need new UCA's but if you do want them I'd recommend Zone's.
DILLIGAF
Canada
skip the spacers, they are big waste of money.
Get bills or ranchos
T
TheDuke
The only reason I was mentioning UCA's is becuase everything I have read suggests that if you go over 2" of lift in the front, your ball joints will popout. Do the Bilstein's keep this from happeing?
DILLIGAF
Canada
Dodge front ends are junk, Might as well change them since you are tearing the truck apart and getting an alignment.
T
TheDuke
I would change the upper control arms and the ball joints but since I don't have the air ride I'm not sure where I need to go from here.
brandonjansen
Yes as long as they're installed correctly. Bilsteins keep the suspension travel within OEM specs which. Spacers allow the suspension to overextend which is where the ball joints pop out.
Saltbreak
Maryland
4.7L V8
I have bilsteins set at 2.1 I think. I have had them on for about 2 years. Only have them in the front. Never experienced any of the 4wd vibration or any other issues.
