Lift kit help
Rob McClure
Portland Oregon
5.7 hemi v8
Hi everyone,
I have a 2015 ram 1500 that I got used , it has a lift kit already on it when I got it I believe it may be a mopar branded lift ? but im not 100% sure, how do i find out what kit it is and if it's a 4 or 6 inch lift ?
thanks for the help,
olyelr
Kewadin MI
Yea gonna need pics of front and rear suspension components. I dont think mopar offered 4-6” kits. If it dosnt have the front lower control arms dropped, its most likely just 2-3” at most.
Rob McClure
Rob McClure
Portland Oregon
5.7 hemi v8
thanks, I added pics to my posting .
olyelr
Kewadin MI
Well its definitely a 4-6” spacer type kit, with spacers over the front struts and drop brackets/extensions.
As to which brand…do the shocks have stickers on them? Any stickers/badging on any other brackets? Are there spacers over/under the rear coils?
Rob McClure
Rob McClure
Portland Oregon
5.7 hemi v8
The diff drop cradles and diff skid look a lot like the zone kit.
the only label li could find is that one in the picture with the bar code , its a mopar shock , ill have to get back under and check the rears
olyelr
Kewadin MI
Yea, the fromt struts are oem units, the lift comes from the spacer on top of them. What brand rear shocks?
Rob McClure
Rob McClure
Portland Oregon
5.7 hemi v8
there is no labelling on the shocks at all , probably not the best pics , it looks like there is something , maybe the spacer on top of the spring ?
Nick@GotExhaust
Supporting Vendor
SC
We were able to work with him and get it figured out. It is a Zone kit with Zone branded rear shocks and OEM struts up front. We got a very nice upgrade shipping out to him real soon.
David Tree
NJ
Adamcr68
Lorton VA
Hemifever 5.7
Has anyone used or 'know of' the use of this front end leveling kit???
@RamDiver @Wild one @CannuckRam1313 @Adamcr68
Everything I’ve seen/read suggest that spacers aren’t your best option, you would be better off getting new struts, but have heard people say the spacers worked for them.
Lots, I mean “lots” of members here have more knowledge than I do, so I can only speak about my experiences, I have Thuren coil overs and a set of Bilsteens to use when I get my shocks rebuilt.
Both preform better than the stock springs, IMO, I never used spacers so can’t say that they are no good but I think you would be happier with a strut level.
Keeping the geometry/angles close to a stock suspenion setup will help save wear & tear on the rest front end parts, again IMO.
David Tree
NJ
How about these for my front end.
olyelr
Kewadin MI
I would have to be paid to put rough country struts on my truck, and even then i probably wouldnt. They are just junk. Thats why they are so cheap.
Go with bilstein, or fox, or eibach, or…anything but rough country lol
Nick@GotExhaust
Supporting Vendor
SC
Spacers cause issues long term. It is well documented here the issues they cause over time. Adjustable struts are the way to go.
ROUGH Country does not last nor does it ride good. Suspension is the item to not go cheap on or you will pay for it. Bilstein 5100's and Eibach struts are the best lower cost option that are good value. They will ride nice and last.
Message me if you would like a quote
David Tree
NJ
Thank You for the FYI
David Tree
NJ
Thank you for the FYI
David Tree
NJ
