Lifter won’t charge
M
Mysfyt
NE Wisconsin
5.9 Magnum
I don’t think we’ll ever know what the issue was with that head other than something in the geometry wasn’t right. Lots of people telling me they never heard of such a thing including me.
Dan98
Well hopefully this salves the issue. I imagine your grandson is excited to get behind the wheel by now.
M
Mysfyt
NE Wisconsin
5.9 Magnum
Finally!!! Purrr purrr purrr! I've been working on this issue since February and today we confirmed it was the head. Here is a video of the engine plus I did a little walk around to show you the whole project. If you people would like, I'll start another thread covering the whole project. I took a lot of pictures along the way.
pacofortacos
I don't remember if you ever said, but on that one cylinder - was the lifter preload (before running) enough that you couldn't spin the push rod?
I have used EQ heads and had bought but didn't get a chance to use a set of CIFIC heads. EQ ports are larger and killed low rpm power, the CIFIC used standard stock ports with harden insert ex. valve seats - machining look better on them than on the EQ.
M
Mysfyt
NE Wisconsin
5.9 Magnum
On TDC you could not spin the pushrod. The head was an ITM brand btw.
pacofortacos
That is a strange problem, that's for sure.
Daw14
South Florida
This can not just be a one off, there must be more of these out there ,making people crazy.
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
That sounds sweet now. I want to do the rocker panels and cab corners on mine. Love to see some more pictures or a write up on that.
M
Mysfyt
NE Wisconsin
5.9 Magnum
Will do. I’ll be gone for a week but I’ll start a new thread. What category should I post it in?
LoneWolf3574
The 3rd Gen DIY section might be best for something like that in my opinion. I'm sure there are a number of folks that would like to do it but have no idea where to start.
