lifters on 5.7 hemi
farmerbrownmt
scobey, mt
2012 diesel--2013 and 2019 5.7 litre
2013 1500 5.7 hemi lifter noise 133,000 mi--- what's the fix or do I trade for chevy or ford? I also have 2019 w/5.7 hemi but no problems with it yet 30,000 mi---I have 2012 3500 w/6.7 diesel only 100,000 mi --Best pickup i've ever owned!!!
jws123
nj
Upload a vid of the noise hemis are noisy engines a lot of ppl think they have noises that aren't normal to a hemi does it misfire any codes?
F
farmerbrownmt
scobey, mt
no codes, doesn't miss--- clicking type rattle when cold disappears as engine warms up
jws123
nj
Like stated above most likely exhaust manifolds also fords and chevys do this to same issue.
srv1
blasdell n.y
345 c.i. HEMI MAGNUM
Injectors can make some clicking noise as well.Get a mechanics stethoscope in there and pinpoint where the noise is coming from.My injectors were making a "clicking type rattle" a while back.I dumped a bottle of redline fuel treatment in and it shut them right up.
Dodge 1500 4X4
Rochester, NY
X2 with noisy injectors, put some redline fuel treatment in the tank.
Marmay
Ontario
My 2019 classic have 28.500 km and is making rattle noise ,some kind of light knock ,not when is cold but after drive and the engine is hot,I am using 5w20 shell rotella full synthetic oil and fram xg ultra synthetic filter,the oil is change every 9.000 km ,so I dont know if this is something to be worry about it or not,no codes no nothing, runs perfect.
Socal1
Nevada
Had a 2013 5.7
Both the left and right lifters were fixed under extended warranty. 34k and 66k miles. Truck ran great just didn't like the noise during warm up.
Killerbee4649
Decatur Texas
Welcome to HEMI ownership bud. “HEMI tick” is normal, just try googling it and you’ll see how common it is and how everyone has conflicting diagnoses.it doesn’t hurt anything and don’t let someone tell you to put in hellcat lifters. They have the same part number as the 5.7 and are no different from what I’ve read and been told. Maybe they improved them? Idk. But definitely check your exhaust manifolds!
Rustaholic
Northridge, California
5.7L HEMI
I have a 2018 Ram Bighorn with the 5.7L Hemi. On cool mornings or if the truck has been sitting a few days, the lifters are really noisy for 3-5 minutes until it’s warm. It only has 15,700 miles on it. This started happening after the 12,000 mile oil change. So it had fresh oil then, just had it changed again, and it’s still doing it. Oil level is good. Maybe time to go Ford or Chevy?
Marmay
Ontario
My 2019 is doing same or similar noise,not when is cold,but warm,it start right after first oil change,just change the oil recently and filter,no change,so now I am planning change the oil filter for mopar ,and if this wont quiet the thick,then I go to the dealer for the diagnostic.
Rdhorton
Columbia SC
5.7 hemi multi displacement
I have 44k on my 2019, 5.7 hemi, and lost compression in the 8th cyclinder...being fix under warranty. Wondering now if I should go with something else.
Marmay
Ontario
I dont know what to say,I have the tick as well 2019 30.000km,very dissatisfied, dealer do the diagnosis and finde nothing wrong,I change the oil from full synthetic to conventional and the tick is down lake 80%,you use your judgment.
