Lookin for.....
Status
Not open for further replies.
Hotroder383
Washington Mo
318 or 5.2 which ever you want
Ok so this is the only place I can think of to post this so all members see it.
Once on the show Trucks I think it was, I seen them do an exhaust exit through the bedside, it was a square pocket that acutally fit flush with the bedside. You had to cut a square out of the bedside weld this into place and the exhaust pipe bolted to the back side. Looked smooth as hell but I'll be damn if I can find it.
Am I crazy or has someone else seen, heard of this before?
WhiteExpress
Midland, TX
StylingTrucks also has them. They are pricey units. Just remember to use a piece of flex pipe to connect them!
1500ram12
5.9L Cummins
Stacey david did it on a dodge truck on either trucks or gears tv.
3rdStrikePerformance
Sikeston, MO
All you need is a box made out of sheet metal with the correct size tubing welded inside it....any competent metal shop can do that for you, at least the box part. The exhaust shop can do the rest...
Hotroder383
Hotroder383
Washington Mo
Stangshcky12
Oshkosh, WI
5.9 Cummins
If you do install that tip you gotta wash the truck often as you'll start to see soot down te bed from the exhaust and eventually there is no gettin it off
Hotroder383
Hotroder383
Washington Mo
Ya, the old mustangs had them come out the rear valance had the same problem. But my truck is the second "car" and I am gonna repaint the the lower part black instead of silver. So I am hopein this wont be as much of an issue.
Status
