Maestro RR - JVC KW-M730BT - 2019 Ram Classic Tradesman - Install Questions
Ignacio Rodriguez
Vehicle: 2019 Ram 1500 Classic Tradesman. RA1 3.0 Radio, No Bluetooth, No steering wheel controls.
I purchased a previously installed JVC KW-M730BT double din that is Maetro compatible. It came with the harness prewired. It was previously installed in a 2017 Ram.
1. I assume I will need to reflash the Maestro RR module to my specific vehicle specs?
2. I'm confused about the connection for the Gauges to come through on the radio. Looking at the pictures I believe I have the 1.6 and earlier harness that requires the Red/Brown and Yellow/Brown cables to connect to CANH and CANL. Does anyone have pictures of where this is (Can Junction Connector (Green)?
3. So am I wrong of Maestro doesn't make a compatible adapter to retain use of the console USB ports? the 19 has 2 and a aux. Where as the Maestro URAM is for a single USB and single AUX.
I
Ignacio Rodriguez
Well, I put the deck in today. All is well except for questions up top 2 and 3. Any help?
Joe Lando III
Saint Augustine, FL
Hey there, I have the same problem actually. Just bought a prewired Maestro rr that was previously in a 2016 ram and mine is a 2018 ram. Getting the same problem with obd2 error message. Did you find any solutions? Thanks!!!
