Mevotech lower control arm cam bolts?
atreides
USA
Has anyone tried Mevotech's lower control arm cam bolts? I picked up a pair to use on my rear bracket and comparing them to the new pair of OEM cam bolts I have, they are a bit different.
Main differences:
mevotechoem
bolt is slotted for the entire length for the boltonly the last inch before the threads is slotted
both cam washers are discretecam washer and bolt head are integrated
has zirks to inject grease and prevent seizingno zirks
tolerance between the cam washers and bolts are a bit liberaltight fitting cam washers
I'm considering using the new OEM hardware in the front bracket and the Mevotech in the rear. Am I taking a risk with the Mevotechs or will I be fine? Are these harder to dial camber/caster with?
