Misfire cylinder 3 !
Tyethorne
Need a bit of advice ...
Having a misfire in cylinder 3
Swapped coils
Changed spark plugs
Checked compression
Changed injector
Still the same problem.
2013 Dodge Ram 1500 5.7 hemi
Demon-HeMi
Houston
2003, 2003, 2008, & 2013
(2) 5.7 HEMI, 3.7, & 3.6
friend of mine just had this happen on his 2014 with cyl. 5
did the same thing you did, dealer found a burnt wire going to the ignition coil...
sock engine BTW...
Tach_tech
5.7L HEMI
Have you done a leak down test? Could have a valve not sealing. Also it may have are the cam, caused by a bad lifter, it’s somewhat common.
I’d do a leak down test first, and if ok, I’d be pulling the valve cover off.
Dodge4x4810
New England
There are a lot of variables...Is your check engine light coming on for the misfire or is someone using a scanner and seeing that the skip is on that cylinder? If you're getting a light, and it comes on fairly quickly after clearing, then it is most likely an electrical issue. If you're not getting a light or it takes a long time to come on, then it is, most likely, a mechanical skip. These engines have always been good, for the most part. If you do not beat the living **** out of it, change your oil, take care of it, etc...then I'm assuming that it is just a stupid electrical issue. Was your compression good?
trip1027
I just had this on mine the cam and lifters had to be replaced
2012 ram 1500 5.7
Sent from my SM-N920V using Tapatalk
huntergreen
Marine Corps Navy Badge
2012 ram 1500 5.7
A likely possibility.
Iyaayas
My 2013 ram 1500 broke a valve spring on cylinder #5. I was getting P0300 & P0305 misfire codes. 41,000 miles. It sounded AWEFUL. I just got it back yesterday, covered under 5/60,000 powertrain warranty
KAKA
