Reddington
- Jun 6, 2017
- 181
- 114
- Location
- Western New York
- 2017
- Hemi 5.7
Just went back and did the sequentials. Love it!
Lol I guess I posted my last question too soon. Just got my resistor pack in the mail. Much better than the giant dual blue ones from the past
Here’s a kit with both connectors- https://www.amazon.com/dp/B074CX33HP/ref=cm_sw_r_cp_api_i_FarKCbRYNP541?tag=viglink21284-20Are there any identifying marks on the large black connectors on each end? I think thats a connector I need for a slightly different project, but could never source the correct part number.
Thanks.
-Chris
The connector on the left side if the adapter pic only had 3 pins, no? The shape makes it look like it might fit the taillight harness.Here’s a kit with both connectors- https://www.amazon.com/dp/B074CX33HP/ref=cm_sw_r_cp_api_i_FarKCbRYNP541?tag=viglink21284-20
The female is the projector truck side connector, and the male is the connector that would be on the factory projector housing.
Not the same connector. That’s just a male/female pass through harness for the projector headlight harness that carries the resistor for the turn signal.The connector on the left side if the adapter pic only had 3 pins, no? The shape makes it look like it might fit the taillight harness.
Sent from my Nexus 6P using Tapatalk
Does anyone have these lights installed on a truck with a chrome grill and chrome bumpers, such as Laramie or Limited? If yes, would you post pictures of your front end, please?
Was the low beam issue the original reason they sent you the “resistor” harnesses (they don’t look like resistors, but rather some kind of capacitor/voltage regulator)?Well I gave it a shot with the resistor harness they sent for the 2015’s but first day of driving with them I’m still losing my low beams after 15 minutes or so... I guess that doesn’t work and I’ll have to go the alfaobd route
