Morimoto XB LED Headlights INSTALLED
jmc0806
NH
2015 Ram 1500 Limited
has anyone with a 2015 received the resistor kit yet?
predat-r
4.7 v8
There u go just disconnect this wire and watch the magic happen.!577b069a3ca2ede090e278a820b558d9.jpg
Sent from my SM-N920P using Tapatalk
jmc0806
NH
Lol I guess I posted my last question too soon. Just got my resistor pack in the mail. Much better than the giant dual blue ones from the past
chrisbh17
Are there any identifying marks on the large black connectors on each end? I think thats a connector I need for a slightly different project, but could never source the correct part number.
Thanks.
-Chris
jmc0806
NH
Nothing really on it except the PIN numbers on the connectors. It was made specifically for the 15’s so I don’t know if they’ll sell it separate or not
Jimmy07
Thanks.
-Chris
Here’s a kit with both connectors- https://www.amazon.com/dp/B074CX33HP/ref=cm_sw_r_cp_api_i_FarKCbRYNP541?tag=viglink21284-20
The female is the projector truck side connector, and the male is the connector that would be on the factory projector housing.
chrisbh17
Jimmy07
The connector on the left side if the adapter pic only had 3 pins, no? The shape makes it look like it might fit the taillight harness.
Sent from my Nexus 6P using Tapatalk
Not the same connector. That’s just a male/female pass through harness for the projector headlight harness that carries the resistor for the turn signal.
Raplon
Does anyone have these lights installed on a truck with a chrome grill and chrome bumpers, such as Laramie or Limited? If yes, would you post pictures of your front end, please?
KWG88ss
Pennsylvania
I do.
White truck, only one headlight works currently though.
jmc0806
NH
Well I gave it a shot with the resistor harness they sent for the 2015’s but first day of driving with them I’m still losing my low beams after 15 minutes or so... I guess that doesn’t work and I’ll have to go the alfaobd route
Jimmy07
Was the low beam issue the original reason they sent you the “resistor” harnesses (they don’t look like resistors, but rather some kind of capacitor/voltage regulator)?
It appears that the harnesses you received are supposed to correct a turn signal/error issue since the wires it is using are #12,13,&14, which are the turn signal driver, ground, and lighting fault sense wires. That harness would have nothing to do with correcting a low beam issue.
jmc0806
NH
Interesting, they were just installed for the first time yesterday, but they told me to wait until I got the resistors before doing so and that’s what came...apparently they sent the wrong thing in that case
Raplon
Joemagnum and jmc0806, thank you for posting pictures both of your trucks look awesome!
