Muffler Question
Bergerman
Richton,Ms
I'm about to order magnaflow muffler from you guys and was just making sure I'm getting the right one. Do I need the 12198 if I'm just swapping the stock muffler for it? And are those clamp on or weld on? Thanks
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
If you have the factory dual exhaust, then that is the correct muffler. It is weld on though because it is about half the size of the stock muffler setup.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
The only clamp on setup would be the complete cat back kits from Magnaflow, or the Mufflex kit which also uses the same Magnaflow muffler. The full catback system comes with all new piping and 5" tips whereas the Mufflex kit is just a clamp on muffler that uses your existing piping and exhaust tips.
Magnaflow Catback Exhaust 2009-2013 Dodge Ram 1500 Dual Rear Exit catback exhaust with 22" muffler and dual 5" polished stainless steel tips
Mufflex 14" Magnaflow Dual Exhaust 09-Up Ram 1500 5.7L Hemi
