My Head Light Build thread. So Far...
OC455
OC455
Central NY
I closed up the headlights and sealed them with the butyl rubber. I think I got everything pretty well cleaned up inside and out aside from the light scratches on the outside of the lenses.
Only other minor mod I need to do is clearance the inside of the upper dust cap, to sit tight and flush with out hitting the D2S plug..
Other than that, ready to go in tomorrow if I get time.360ec666f5b7603715ff7ad31313262a.jpgbc61cfe550754a652f89a5d7fdebe495.jpg2a0aa72cfa517c3c4f0b7048c15d552f.jpg4d7596660910b8098791412ac9c82623.jpg3c1fbdffba8c4b8d631b2d708526181e.jpg417ac056135c69211da04982551b783b.jpg74afc6a84c089e97e9862f457631056c.jpg
OC455
OC455
Central NY
Got them.in and set AlfaOBD to where they needed to be.
So far they look good and no bulb out errors.2d7c66778cd232b2d6bc25be9b5f8b69.jpg4d97c3f817f99b6f1d06b2ce7b9c1bd5.jpgaeeb955d164957d9aaba015a771d273c.jpg9d926b42f51924afe9b5f40ee0002702.jpgef7d6c207a062ae1bd53ab14075debdb.jpgf8e857801490f4c9e4a9dab3d4e0b369.jpgdae5a0500d29f0ea3c27e24206dbdbf9.jpg
OC455
OC455
Central NY
I did notice that when I turned off the lights and was in drive, the high beams were on for the DRL. They were not very bright, and the passenger side was dimmer than the driver's side.
1500ram12
5.9L Cummins
The drl voltage is only like 7.4v I believe maybe less with high beams. You should be able to change the voltage with alphaobd. I know you can for dedicated drl's
OC455
OC455
Central NY
1500ram12
5.9L Cummins
Also Do you have your drl's set to led's
RusslRam
Unless required by law or needed I would turn off high beam as DRL and just use parking lights as your DRL. I would hate for the high beams to be over worked and fail. I doubt they will but still a little piece of mind after all that hard work. Turn signal/switchbacks are a lot easier to replace.
Sent from my Pixel using Tapatalk
1500ram12
5.9L Cummins
The Hi-Lense does have a drl feature. He would have to run the dedicated drl feed to use it or tap into the parking lights.
hemili8r
London ontario canada
Wow I have the same issue with my morimotos in gear in off position they went bright but in park it was normal..wow same issue.
No issue other than that. Love these lights. abcd19abed332575d8130ee758c590d4.jpg
Sent from my SM-N960W using Tapatalk
hemili8r
OC455
OC455
Central NY
Maybe I will just do that. I think DRL feature helped me out a few times when I was driving. Not required by law, but I also dont need to be pulled over because of a pulsing white light, which is not legal. I dont need switchbacks to have it run as a DRl do.I?
1500ram12
5.9L Cummins
Nope. Just with the switchbacks you'd have a white drl not amber.
OC455
OC455
Central NY
I love the way these look.
The black bezels and the chrome shrouds and buckets. Pretty much in my opinion a good mix of black and chrome. db1b05c60367b332d6c613b19997e5a9.jpg1787d0c28e58167b674ee818082d8155.jpg
OC455
OC455
Central NY
Need to finish up the fog light projector build now.... :)
OC455
OC455
Central NY
I think I may need to adjust my lights up a bit. Low beams seem like they are only lighting up just in front of the truck.
OC455
OC455
Central NY
List of things I actually used to build my headlights.
Morimoto Mini D2S projectors (low/high beam): https://www.theretrofitsource.com/bi-xenon-morimoto-mini-d2s-4-0-projectors-55833.html
Profile Hi-Lens LED projectors (high beam): https://www.theretrofitsource.com/bi-led-profile-hi-lens-led-high-beam.html
9006/9005 splitters x2: https://www.theretrofitsource.com/high-beam-splitters.html
D2S to AMP 90 degree connector x2: https://www.theretrofitsource.com/amp-to-d2s-ballast-adapters.html
AMP extension: https://www.theretrofitsource.com/amp-extensions-49122.html (modified, bought AMP connectors 2 male/2 female)
H11/9006 adapter x2: https://www.theretrofitsource.com/headlight-socket-adapters.html?preselect=49229
Morimoto XB55 ballasts/ignitors x2: https://www.theretrofitsource.com/amp-morimoto-xb55.html
Morimoto XB50 D2S bulbs 5800k x2: https://www.theretrofitsource.com/d2s-50w-morimoto-xb-hid.html?preselect=54703
Morimoto Retro-rubber: https://www.theretrofitsource.com/morimoto-retrorubber-butyl-glue-52001.html
Gatling Gun 1.0 shrouds: https://www.theretrofitsource.com/gatling-gun-1-471.html
Wiring seal (4 wire) x2: https://www.theretrofitsource.com/4-position-wiring-seal.html
Motohold2rs: https://www.theretrofitsource.com/morimoto-mini-d2s-moto-hold2rs-bulb-lock-rings.html
Profile Peak 3157 amber LED turn signals
Did not use any of the other items(wiring harness) I thought I would need because I purchased the AlfaOBD app and the MX bluetooth dongle. JB Weld to attach the shrouds. Krylon satin black spray paint for the OEM bezel.
OC455
OC455
Central NY
I set my DRL's to the turn/park signals. They light up nice and bright. I'm thinking maybe some Profile Peak switchback 3157's......I dunno. I don't want to take the lights out again. LOL.
OC455
OC455
Central NY
One of the big things that I confused myself with more than anything was how to wire the HIDs with the LED projectors.
Using AlfaOBD eliminated the wiring harness and relays. If this helps anyone with how to get everything hooked up and working, cool.
Guillermo Arevalo
California
so the high beam splitter basically lifts the shutter in the projector so that also works as a high beam right?
OC455
OC455
Central NY
Yes.
I didn't have a spare projector laying around to hook up....LOL
Even if you didn't use a LED projector like the Hi-Lens, you could keep it a stock halogen or replace it with a quality LED bulb in the housing, still utilizing the splitter to activate the shutter solenoid. Or not use the splitter at all, and just plug in the OEM harness into the high beam bulb and forego using the projector solenoid.
Confused yet??? :) There are a few things that can be done option wise when building.
